I am referring to a 5D and BG-E4. I only have an original BP-511 (relatively newer and better in terms of capacity) and 2 other 3rd-party batteries. My concern is that the batteries were purchased at different time and there may be a gap in condition (voltage, capacity). I usually used them individually in the camera. But now i would like to add the battery grip to improve handling when using a heavier lens
May I know how a battery grip (BG) manage power from 2 Li-ion rechargeable batteries?
Normally, a BG takes an array of 6 AAs in a tray which gives a typical 7.2V that is equivalent to 1 Li-ion. So I assume all 6 works at the same time.
I'm interested to know what goes on inside when the BG is loaded with 2 standard Li-ion rechargeable batteries. Does it switch from one to another, or work in parallel?
If it switches, would there be an indication or marking on which chamber is 1st priority? This method (if so) is of lesser concern in that I would incline to put the better battery in there, and a backup battery in the other chamber, while have a 3rd battery in the pocket.
On the other hand, if 2 chambers work in parallel, I would have to consider changing all my batteries to the same brand and capacity because I am quite sure the batteries I have varies in voltage and may not be efficient when used in parallel.
