Thread started 01 Sep 2016 (Thursday) 23:18
External Flash? SX500 IS
KirkS518
Joined Apr 2012
Sep 01, 2016 23:18 |  #1
I decided that I wanted a bridge/P&S camera (I have a 50D, but shoot mostly medium format film), and being a Canon fanboy since 1978, I searched for Canons. I really know nothing about these cameras, so I started searching ebay for cheap (<$100) cameras that fit my needs. I must have watched a video for a different camera, as I could have sworn it showed how the SX500 has a hotshoe under the cover on the top. I just figured out it's a mic, not a hotshoe cover.
Anyway, is there a way to shoot an external flash with the SX500? I don't have the camera in hand yet, so I'm trying to decide if I'm going to keep it or not.
If it can't be done with the SX500, what bridge/p&s does? I'll be using it mainly for product shots with multiple flashes on triggers. I decided that using my 50D for this purpose is overkill, so that's where this camera come in.
My needs are:
Full Manual Control
External Flash capability
>10mb
<$100 (the cheaper the better)
1 ft or less minimum focus distance (macro mode, but I don't need 0" minimum)
Tripod socket would be useful (I think almost all have this)
Decent IQ
RAW would be a bonus
I'm not really concerned about:
Age
Type of Memory card
Zoom range
AF speed
Noise
Processing speed
Physical size/weight
Thanks!
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
Pictoraider
Joined May 2016
Post edited over 7 years ago by Pictoraider.
Sep 02, 2016 05:24 |  #2
SX500 doesn't deliver RAW format and is subject to AC despite internal optical corrections.
Any Canon P&S with hotshoe can synchronisze with external flash.
If no hotshoe, Canon P&S such as Powershot S95, S100, S110, S120, G7X, G9X can have their popup flash turned into manual mode with low output level : so that this popup flash can be used to activate at distance any studio flash or any external flash via an optical slave cell...
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/1/LQ_811100.jpg
Image hosted by forum (811100) © Pictoraider [SHARE LINK]
"Constructive criticism always appreciated."
KirkS518
Joined Apr 2012
Sep 02, 2016 08:35 |  #3
Yeah, I was aware the SX500 didn't shoot RAW, but RAW is not necessary.
I'll give using the built-in flash a try as Master on Low, and I have optical slave sensors, so that's no problem. My only concern is how much light gets put out in Low, considering it isn't a 'master' flash setting, so it won't fire like a Master, and the light will affect the image captured. But it is a possibility.
Pictoraider
Joined May 2016
Post edited over 7 years ago by Pictoraider. (3 edits in all)
Sep 02, 2016 11:26 |  #4
The built-in flash of the SX500IS can't be switched into manual mode.
It's only available for some Canon P&S such as S95, S100, S110, S120, G7X, G9X and for Canon P&S with hot-shoe. (cf Manual of each product)
With these Canon P&S, if it is for indoor photo with external flash and you proceed with 100 ISO and 1/250รจ s as shutter speed, the low level of out put won't be very much and not noticeable ; in all other cases, you have the possibility to hide the major part of the popup's light : the optical slave sensor will work as well.
Regards,
2,734 views & 0 likes for this thread, 2 members have posted to it.
1053 guests, 104 members online
