MalVeauX wrote in post #18114536
I prefer a wired mouse that you can turn down the acceleration on, so that your movements are precise and smooth, and I prefer the added option to put weights into the mouse so that it's heavy, which helps you to make smooth movements. So I use an old Logitech G5 with maximum weights installed, and the acceleration turned to minimum, on a Kabuto surface material. It's butter smooth, heavy, and doesn't wobble.
I had a G5 as well, shame that it started bugging out a few years ago, otherwise it worked well for like 6 years. I'm currently using some throwaway $5 mouse in the mean time, but it's okay because I mostly use a Wacom tablet for everything anyway. If I had to buy a new one today it would probably be the new Logitech G Pro, since it's pretty much a minimalist G502 or slightly bigger G302, which is what I wanted for a while now.
twists n turns wrote in post #18114532
My mouse is on the road out I think. Im making selections in PS and half way round its losing the signal. Its a
Microsoft sidewinder. Served me well over the last 6yrs or so.
What mouse do you guys use?
Anyone like recommend one? Budget about £40 max. Doesn't have to be wireless, I don't mind it wired. I remember wired ones having greater input accuracy. Have things moved on or is that still the case today?
Generally you'll want any nice optical mouse, as those have the fewest "issues" with precise motion; like acceleration, angle-snapping, and jitter. This will make drawing selections much easier in Photoshop and such.
As far as accuracy goes, the G900 is said to be the best in this regard, but it's absurdly expensive and the charge lasts for only a few hours, which is the price for driving a high-precision optical sensor. Nearly every other wireless mouse will use lasers and use a whole host of techniques to minimize battery drain, which doesn't reflect well on performance.
