Thread started 02 Sep 2016 (Friday) 14:02
Lightroom Oversaturation Issue
96whiteknight
PERMANENT BAN
Gallery: 11 photos
Sep 02, 2016 14:02 |  #1
Nothing has been edited on the two attached photos. These were shot with my 7D, but my 5D Mark III does the same thing. It happens most when I'm shooting night events with colored lighting. Is this really how the untouched RAW photo should look? If so, how do I fix it in LR? If not, why does it look like this?
Thanks for any help!
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/1/LQ_811136.jpg
Image hosted by forum (811136) © 96whiteknight [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/1/LQ_811137.jpg
Image hosted by forum (811137) © 96whiteknight [SHARE LINK]
JTbandy
Sep 02, 2016 14:10 |  #2
It looks kinda like some clipping warning. I don't know enough about it to even comment.
96whiteknight
PERMANENT BAN
Gallery: 11 photos
Sep 02, 2016 14:50 as a reply to  @ JTbandy's post |  #3
Nope, it's in the JPG conversion, too.
IMAGE: https://c7.staticflickr.com/1/519/19512775246_36e22d43a3_b.jpg
IMAGE LINK: https://flic.kr/p/vJh5​gq  (external link)
Untitled (external link) by Michael Bartley (external link), on Flickr
tonylong
...winded
Gallery: 60 photos
Sep 02, 2016 16:34 |  #4
What happens if you go to the HSL section in the Develop panel and tweak the Blue settings?
Tony
BigAl007
Gallery: 556 photos
Sep 02, 2016 17:11 |  #5
The thing is that it "What you see in LR" is not the RAW unprocessed data! What you are seeing is the DEFAULT processed conversion. It is also very easy to change the LR default settings, and you can even set them up to be different for each body (by serial number so two identical cameras could still have different defaults) and on top of by serial number you can also specify by ISO value. So you could potentially have more than thirty different sets of default settings for each camera.It could be that you have a default for higher ISO values that has had the blue channel saturation turned right up by accident. Also check your colour profile, and associated colour settings, again it is easy to get that misset and saved as a default.
Also remember that those Angle hair light pipes, with xenon bulbs are very blue, and could easily be overexposed, and the WB will be way off from other most sources of artificial illumination. So it might not even be an actual processing problem.
Alan
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket.
Sep 02, 2016 17:19 |  #6
i'm guessing that it is not a raw conversion or lightroom issue, but rather an out of gamut problem encountered at the time of capture. The camera basically gets confused and throws those sets of pixels into some weird spot on the spectrum. I've seen yellows get thrown into bright red sunsets, and came across something with stage lighting at one point but forget what it was.
if you can share the RAW, I can open it in Capture One and check it out. Actually, if you have a new camera, will you DNG it first? I have the converter but it probably isn't the most recent version. I can do 6D and earlier.
96whiteknight
PERMANENT BAN
Gallery: 11 photos
Sep 02, 2016 19:39 as a reply to  @ tonylong's post |  #7
Still looks pretty bad
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/1/LQ_811186.jpg
Image hosted by forum (811186) © 96whiteknight [SHARE LINK]
96whiteknight
PERMANENT BAN
Gallery: 11 photos
Sep 02, 2016 20:15 as a reply to  @ Left Handed Brisket's post |  #8
I appreciate the help! Not sure if I'm doing this right. Let me know if this works.
https://www.dropbox.co​m …z30yyne/IMG_338​7.CR2?dl=0 (external link)
Gallery: 15 photos
Joined Jun 2011
Sep 02, 2016 20:37 |  #9
96whiteknight wrote in post #18115065 (external link)
no problem.
interesting result. I converted it to DNG with Adobe's DNG converter and opened it with CS4 and it looked pretty much just like your original post. Then when I opened them in Capture One I imported both images. The original CR2 looks much more realistic. Its the pic on the left what you were expecting?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/1/LQ_811190.jpg
Image hosted by forum (811190) © Left Handed Brisket [SHARE LINK]
96whiteknight
PERMANENT BAN
Gallery: 11 photos
Sep 02, 2016 21:09 as a reply to  @ Left Handed Brisket's post |  #10
Awesome. So, it's LR, then?
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Sep 02, 2016 22:30 as a reply to  @ 96whiteknight's post |  #11
These are LED ring lights, no? To me it looks very similar to the problem found in many small clubs and concert venues with LED stage lighting.
Due to the technology used in lower cost LED systems, some colors, usually magentas and purples, photograph extremely saturated, to the point of blowing a channel.
This looks to be related to that.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
Redcrown
Sep 03, 2016 00:26 |  #12
This is where a program like Rawdigger is useful.
http://www.rawdigger.c​om/ (external link)
Download the trial and load this raw image. Go through the overexposure display channel by channel. Look at the raw histograms.
You will see the raw is toasted. No converter can save it.
mclaren777
Joined May 2012
Sep 03, 2016 03:30 |  #13
There's an easy solution for this: change the profile in the Calibration panel to something other than Adobe Standard
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
BigAl007
Gallery: 556 photos
Sep 03, 2016 06:12 |  #14
mclaren777 wrote in post #18115327 (external link)
If as suspected the image is actually blown in one or more channel then changing the profile is very unlikely to help. The Adobe Standard profile is pretty good usually, and IMO unlikely to be the cause of this issue. Now Camera Landscape, that would be a different proposition.
Alan
Gallery: 15 photos
Joined Jun 2011
Sep 03, 2016 06:32 |  #15
96whiteknight wrote in post #18115100 (external link)
is theh Capture One conversion of the original RAW "correct"? I haven't really studied BMW running lights lately, but I seem to think that is what they are supposed to look like.
Redcrown wrote in post #18115265 (external link)
Assuming you opened the file with RawDigger and that the Capture One version is correct ... that would make the bold incorrect, right?
6,744 views & 2 likes for this thread, 11 members have posted to it and it is followed by 4 members.
1472 guests, 133 members online
