Thread started 03 Sep 2016 (Saturday) 13:28
Mirror Slap
DigitalDon
Joined Aug 2012
Post edited over 7 years ago by DigitalDon. (3 edits in all)
Sep 03, 2016 13:28 |  #1
My 50 mm lens the focus ring is so sensitive, while using it in live view I get focused and just removing my fingers from it can sometimes throws focus out of whack.
I was wondering if the mirror moving out of the way of the sensor (mirror slap) could be throwing the lens out of focus.
T3i.
I decided to do a test, set my camera on a sturdy tripod, camera set to AV mode, camera auto focus off, turned the adjustment ring, perfect focus in live View, I pressed the shutter button half way and the news paper moved in the live view screen, let off the button it moved again, what's up with this
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
BigAl007
Gallery: 556 photos
Sep 03, 2016 15:53 |  #2
Well if you are actually pressing the button on the top of the camera, I don't care how good your tripod/head combination is you will be moving the camera a little. When using LV there is zero possibility of mirror slap though, the mirror is already up to enable the LV to work, so there is no mirror movement.
Alan
maverick75
Joined May 2012
Sep 03, 2016 16:10 |  #3
If you're getting movement is might be from the shutter, although I find shutter to be dampened really well on DSLRS. On mirrorless cameras it is more severe since they dont have a mirror box to take the sudden movement, also makes them really loud. on my 7D I can handhold 1/5 no problem but on my EOS M 1/30 is pushing it.
DigitalDon
Joined Aug 2012
Sep 03, 2016 17:04 |  #4
BigAl007 wrote in post #18115852 (external link)
Alan
Thanks BigAl007
Forgot to mention I was using wireless triggers, I was pressing the button on the camera at first then I switched on the triggers
Update I tested LV and you are right the mirror is locked in LV.
DigitalDon
Joined Aug 2012
Post edited over 7 years ago by DigitalDon. (2 edits in all)
Sep 03, 2016 17:15 |  #5
maverick75 wrote in post #18115883 (external link)
Thanks maverick75
In the custom settings I set it to mirror lock up, the thing I've noticed when I press the button to take the picture I hear the mirror flip up then I have to press the button again to take the picture, I'm still wondering if the mirror opening could cause the sensitive focus ring to move focus ever so slightly.
saea501
... spilled over a little on the panties
Gallery: 43 photos
Sep 04, 2016 06:34 |  #6
DigitalDon wrote in post #18115713 (external link)
T3i.
From this description......is IS turned off? I have seen this kind of behavior when I forgot to turn off IS and had the camera on a tripod.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
DigitalDon
Joined Aug 2012
Sep 04, 2016 06:44 |  #7
saea501 wrote in post #18116378 (external link)
Thanks, I hadn't though about that, I will give it a try, just turned off IS and that fixed it imagine doesn't move, problem solved, thank you, thank you, thank you.
Wilt
Sep 04, 2016 11:58 |  #8
DigitalDon wrote in post #18115934 (external link)
Thanks maverick75
One would think that if mirror slap shifted lens focus enough to be an issue, we would have a lot of out of focus shots...after all, even when AF with no manual focus intervention, shots should be shifted out of focus then, too.
chuckmiller
Gallery: 65 photos
Joined May 2012
Sep 04, 2016 18:48 |  #9
Shouldn't the focus ring be a little tighter and require just s bit more effort, to stabilize it?
Retired from Fire/Rescue with 30 years on the job - January 2019
DigitalDon
Joined Aug 2012
Sep 04, 2016 21:45 |  #10
chuckmiller wrote in post #18117022 (external link)
I would think so, I don't know how to explain it, nearest thing I can think is, its not as severe as a lose filter or filter holder but it close to it. My other two lens the rings are snug.
The 50mm is a canon I bought it on eBay from China I think at the time I bought it the American Canon was a lot more expensive.
Thank You chuckmiller for replying to my post.
DigitalDon
Joined Aug 2012
Sep 04, 2016 21:48 |  #11
Wilt wrote in post #18116645 (external link)
Makes sense to me thanks Wilt
saea501
Gallery: 43 photos
Sep 05, 2016 07:01 |  #12
DigitalDon wrote in post #18116386 (external link)
Most welcome. Glad you got it sorted out.
Bob
DigitalDon
Joined Aug 2012
Sep 05, 2016 07:07 |  #13
saea501 wrote in post #18117428 (external link)
There's probably a simple explanation for why the image moves, but, nothing is simple for me ߘ
saea501
Gallery: 43 photos
Sep 06, 2016 06:39 |  #14
DigitalDon wrote in post #18117432 (external link)
It's not very simple. The IS system can cause minute vibrations of it's own when operational. Sitting on a tripod the only vibration would be caused when we touch the camera or tripod. IS responds within .0002 of a second and as the lens group moves to make the correction it generates minute vibrations of it's own thereby triggering an additional correction and a sort of feedback loop which can be seen through the lens as movement.
Bob
PacAce
Joined Feb 2003
Sep 06, 2016 07:28 |  #15
That's odd. I didn't think that any of Canon's 50mm lenses had IS on it. -?
...Leo
5,607 views & 0 likes for this thread, 7 members have posted to it.
Mirror Slap
1047 guests, 105 members online
