Thread started 05 Sep 2016 (Monday) 11:19
Micro focusing technique
chauncey
Sep 05, 2016 11:19 |  #1
Any of the instructions for micro-focusing adjustments indicate that the focusing target be in perfect focus...
taking into consideration that your in-focus area is about half in front and half behind the subject,
would it not make more sense to set that up to back focus just a bit?
BigAl007
Gallery: 556 photos
Sep 07, 2016 04:53 |  #2
chauncey wrote in post #18117667 (external link)
No I would not try to take DoF into account when setting MFA. DoF is NOT a fixed property, since it relies on final image size, as well as viewing distance. Also there is only one infinitely narrow plane of focus, as we move away from that plane the image ceases to be composed of infinitely small points, and starts to become blur circles instead. With a planar subject, which a focus test chart is, you want the plane of focus to also be exactly at the sensor to resolve maximum detail. In a 3D subject you would be very disappointed if for example you focused on the surface of the eyeball, and actually got one of the eyelashes in perfect focus.
Alan
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Post edited over 7 years ago by Dan Marchant. (2 edits in all)
Sep 07, 2016 07:39 |  #3
taking into consideration that your in-focus area is about half in front and half behind the subject, would it not make more sense to set that up to back focus just a bit?
No because the in-focus area is only the plane of focus. Everything else is increasingly more out of focus. The area of acceptable focus/out of focus is as Al points out perceptual and is based on the final image size/viewing distance etc.
Also the area that is acceptably out of focus isn't always "about half in front and half behind the subject". At different settings it can alter from that dramatically.
Dan Marchant
1,519 views & 1 like for this thread, 3 members have posted to it.
909 guests, 119 members online
