ThomasDidymus wrote in post #18119550
Just Got a Sony 70-200 F4. I want a set of Graduated filters for it as well as my nikon gear.
I know Lee's are the best but want other options and have no clue were to start.
I also do no undersand the value system of the ND as far as the darkness scale goes.
Any help would go a long way.
What's your goal with these grad ND filters in the fist place? What kind of horizons are you going to be shooting? Will anything be in the horizon? I ask because if you're shooting water with a relatively straight horizon and nothing coming up from it (trees, mountains, structures, etc), grad NDs can be effective; but if you're doing landscapes without a straight horizon you will have issues darkening things that raise above the graduating line. Also, the kind of grad ND you get depends again on what you're trying to stop down. A soft edge graduated ND will have a slow transition of non-ND to full strength ND from the line to the top of the filter, to stop down bright portions of the sky relative to foreground, and the soft edge is good if you need some blending at the horizon due to there not being a distinct line horizon (such as distant foliage, etc). A hard edge is good for when there's a distinct line edge, like water to sky. A reverse grad ND is good for when there is a bright source of light at the horizon, such as sunsets/sunrises with the sun at the horizon and not high in the sky.
As someone else already explained, the stop system is the easiest to deal with. You will find them labeled in several ways. Stops is the easiest though (1 through up to 15). But lots are listed in fractions (ie, ND8 being 1/8th or 3 stops).
Very best,
