I've noticed a thread for the YN 622 c Tx but what do you think about the YN 560III controller
http://www.ebay.com …c9b811:g:lfEAAOSwGWNUYccO![]()
ORhttp://www.ebay.com …c110ab:g:K-cAAOSwuAVWz9ek![]()
DigitalDon Senior Member More info Post edited over 7 years ago by DigitalDon. (2 edits in all) | Sep 09, 2016 17:00 | #1 I've noticed a thread for the YN 622 c Tx but what do you think about the YN 560III controller
BlackeyCole Senior Member 480 posts Likes: 21 Joined Feb 2007 Location: Alamogordo New Mexico More info | Sep 10, 2016 05:21 | #2 These may be cheap and they may some part or none of the time and that's great for hobbiest starting out but you really ne to look at pocket wizards as the are the standard for generic radio controlled light controllers. The non ITTL models work for triggering almost any light remotely with or without cables and adapters but they can be setup to trigger a remote camera and flash. The ITTL models work with either Nikon or canon, radio specific , speedlites and controls more than just triggering the light they can change the power level either manually or automatically depending on you setup. You also get a few other tricks and features that I've not mentioned. Click Here and Join the POTN flickr Group Today!
smarti77 Member 100 posts Likes: 21 Joined Mar 2010 Location: Adelaide, South Australia More info Post edited over 7 years ago by smarti77. | Sep 10, 2016 06:40 | #3 I've used a YN622c tx for a long time now, on with my 5DIII and 7D, and with a a variety of YN and Canon flashes. ...
LeftHandedBrisket Combating camera shame since 1977... More info | Sep 10, 2016 08:06 | #4 YN controllers have worked flawlessly for me, and many other folks on the forum. I only do a little OCF with TTL but all my studio and most of my event work is with OCF. Can't ever recall a misfire or a problem getting things set up. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
DigitalDon THREAD STARTER Senior Member More info Post edited over 7 years ago by DigitalDon. (3 edits in all) | Sep 10, 2016 09:22 | #5 Thanks guys
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 7 years ago by Left Handed Brisket. | Sep 10, 2016 09:43 | #6 DigitalDon wrote in post #18123240 Thanks guys I am limited in how much I can spend on camera equipment, very limited. I've had great luck with yongnuo flashes, I have 2 YN 560II and a Yongnuo 565EX, I use 603c II triggers and I've been happy with them, recently bought a octagon 47" softbox umbrella with defuser that I have to take half way off to adjust flash output power, then most of the time the flash is in an angle that makes it hard to read the flash settings. I know it would make life easier to be able to set the output power and zoom from the camera. Is it possible to say use one of the 603 triggers mounted on camera and use another to trigger the camera and flash, and use the 560 tx controller as a remote off camera to set the output power and zoom on the flashes Thanks to all of you for your help i don't see why not. The 560TX does not need to be connected to the camera to control the flashes. As long as all your flashes are able to be triggered by the 603 you should be good. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Sep 10, 2016 10:53 | #7 Left Handed Brisket wrote in post #18123256 i don't see why not. The 560TX does not need to be connected to the camera to control the flashes. As long as all your flashes are able to be triggered by the 603 you should be good. i have the 603II and the 622C and have used them in all kinds of configurations, including with the Godox/Cheetah controller for my 360. as an example of silliness, I was doing a kind of selfie the other day and had one 603 plugged into my 6D trigger port and just hanging off the camera. In the hotshoe I had the 622 and then in it I had the FT-16. I was able to control my 580 from the camera menu through the 622 and the 360 was controlled through the FT-16. I of course released the shutter with another handheld 603 I can also set up the camera with the 622 in the hotshoe, the 603 in the 622, and then the FT-16 in the 603, using the single 603 for some old non TTL flashes AND releasing the shutter. It ain't pretty, but it works. Obviously my set up is a hodgepodge of older gear, so using one controller on camera that doesn't have a hotshoe isn't going to work for me, plus I only have one canon TTL flash anyway. Thanks Left Handed Brisket
| Latest registered member is semonsters 1047 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
