domat wrote in post #18123266
So far I have only been using single point af for everything I do. In the past my cameras didn't even have that much of a choice (5dii 50d) now with my 80d and its 348 points I am thinking perhaps I should branch out especially with my upcoming travels to South Africa in a few days.
So when do you use multiple points over single?
Portraits? I assume that single to the eye is still the best bet?
BIF?
stationary birds?
Large mammals?
Landscapes?
Thanks in advance.
@Dangeladventures
@danknafophoto
Depends on how you shoot.
Some will use all points and just let the camera decide what's important to focus on.
Some will tell the system to use specific groups of points to have a small area that will latch onto something in an area.
Some will stick to single point precision.
I do both, but I never use all the points. Sometimes I do single point, but I tell the camera which point I want to use. Sometimes I use a group of points, like zones (center, left, right, up, down) with expanded points around a cross point in that zone, when I'm chasing something but can't keep a precise lock, I left the extra points help keep a lock or good odds to keep a lock, this is useful for fast moving things at close range I find. I more often however end up back on using a single point, and I simply lower AI servo's sensitivity and to me, this gives me the best results for BIF.
For landscape, I focus on the closest feature I know I want focus on, if I know the depth of field will take me to the horizon (assuming I want everything in focus). I don't focus on the horizon and then stop down. The focus point pretty much doesn't matter in this case since I'm generally focusing once and composing afterwards from there.
I have many cameras and only one of them has an advanced AF system with zones, expansion, groups, etc, and I learned to use all those zones and liked it, but I found for precise BIF, I still go back to single point with low AI servo sensitivity, and sometimes I will simply move that single point that I use for spot focus where I think I want it to be to compose for my subject (center is not always ideal on something close range that is filling the frame for example, so I may shift the point left or right to track the head of the bird and keep the whole body in the frame for composition.
I could live with single point AF though, even if it was center, as I use that for almost everything anyways. I recompose as needed. Old habit, but it doesn't hold me back or cause errors, so I've yet to move to something else.
Very best,
