Does anyone know if I can use the computer cable from my 50D on a 5DMK2 - or are they all camera-specific? Don't want to buy another cable if I can avoid it.
Thanks all.
greyswan I have just suddenly realised just how deranged I am More info | Sep 12, 2016 06:03 | #1 Does anyone know if I can use the computer cable from my 50D on a 5DMK2 - or are they all camera-specific? Don't want to buy another cable if I can avoid it. Chris
IanE Member 216 posts Likes: 5 Joined Apr 2010 Location: Bath, UK More info | Sep 12, 2016 06:05 | #2 You'll be fine, they're all the same.
Sep 12, 2016 19:02 | #3 Thanks Ian, much appreciated. Chris
GregDunn Goldmember 1,289 posts Likes: 132 Joined Mar 2013 Location: Indiana More info | Sep 13, 2016 10:09 | #4 Yes, as long as the connector fits, you're good to go. Interestingly, as long as you're not using it for a hard drive, a micro-USB connector will actually work on a USB3 device - at USB2 speeds. There are 2 separate sections to the connector, one of which matches the USB2 pinout and the other has the USB3 high speed lanes. I've done this in a pinch when I couldn't find a proper USB3 cable. Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
Mike ugly when I'm sober More info | Sep 13, 2016 10:23 | #5 GregDunn wrote in post #18126583 Yes, as long as the connector fits, you're good to go. Interestingly, as long as you're not using it for a hard drive, a micro-USB connector will actually work on a USB3 device - at USB2 speeds. There are 2 separate sections to the connector, one of which matches the USB2 pinout and the other has the USB3 high speed lanes. I've done this in a pinch when I couldn't find a proper USB3 cable. That's a good thing to know!! Thanks www.mikegreenphotography.co.uk
Sep 13, 2016 19:09 | #6 Thanks much Greg, good to know indeed. Chris
| Latest registered member is griggt 832 guests, 166 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
