Thread started 16 Sep 2016 (Friday) 21:14
Canon 7D MKii AF Point On Playback
Mudhog79
Gallery: 12 photos
Sep 16, 2016 21:14 |  #1
Hello,
I had the AF point to be displayed turned on when i play back my pictures. I recall seeing it a while back but have not really noticed it lately. I have sense upgraded the firmware on the camera. Today i wanted to see the AF points on my pictures during playback but they are not showing up. I checked in the menu and i have the feature turned on. These particular pictures i took with my 430EXII flash on the camera if that matters. Any idea what is up?
Canon EOS 7D Mark II, EFS 55-250mm IS, EF 50mm f/1.4, EFS 17-55 mm f/2.8 IS, 430 EXII Speedlite, Fiesol 3441T, Photo Clam PC-40NS
FramedMoments (external link)
rrblint
Gallery: 84 photos
Joined May 2012
Sep 16, 2016 22:55 |  #2
Are you using back button focus?
Mark
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Sep 16, 2016 23:26 |  #3
On the third page of the Play menus (blue menus), Enable "AF Point Display". Sounds like something turned it off in the update process.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 16, 2016 23:36 |  #4
Mudhog79 wrote in post #18130492 (external link)
Hello,
Snydremark wrote in post #18130573 (external link)
Mark
Snydremark
Gallery: 66 photos
Sep 16, 2016 23:41 |  #5
Want to make sure the correct setting is being checked, as there is also "VF display illumination" under the AF menu, which could be mistake for the same setting.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 16, 2016 23:43 |  #6
Snydremark wrote in post #18130582 (external link)
Ahhhh, I see.:-)
Mark
Snydremark
Gallery: 66 photos
Sep 16, 2016 23:50 |  #7
"mistaken"...I r spel gud. The other option, which I assume you were looking toward is that if the focus button is not held down when the photo is snapped, the af point is not displayed on the screen.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 17, 2016 00:37 |  #8
Snydremark wrote in post #18130589 (external link)
Yes, that is correct. It can be very confusing causing some photos to have visible FPs and some to not have them, seemingly in a random fashion if one doesn't recall which were taken after letting go of the BB.
Mark
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 7 years ago by mwsilver. (2 edits in all)
Sep 17, 2016 00:38 |  #9
Hello,
If you have Distortion enabled for the Lens aberration correction feature on the first shooting menu, and you are using a Canon lens with an uploaded profile, the focus points will not show because after distortion correction they are no longer relevant.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
Mudhog79
Gallery: 12 photos
Sep 17, 2016 13:57 |  #10
No, i checked again, "AF Point Display" is enabled.
Mudhog79
Gallery: 12 photos
Sep 17, 2016 13:58 |  #11
rrblint wrote in post #18130553 (external link)
Not yet, one day...... i hear it is worth it.
Mudhog79
Gallery: 12 photos
Sep 17, 2016 14:00 |  #12
mwsilver wrote in post #18130616 (external link)
This was it! So why is my AF point still not my AF point after this?
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 7 years ago by mwsilver. (3 edits in all)
Sep 17, 2016 14:35 |  #13
Mudhog79 wrote in post #18131048 (external link)
They should be on new images you capture. The previous images have already been modified with distortion correction info which modifies the shape of the image. Once done the original position of the points in the image are no longer accurate or relevant so they are not displayed. For instance, if originally the center focus point was on a person's right eye, after distortion correction the eye may have shifted and the display of the focal point might now be on the nose or between the eyes. The image is no longer the one you took so the focus point locations are no longer relevant.
Mark
Snydremark
Gallery: 66 photos
Sep 17, 2016 14:45 |  #14
mwsilver wrote in post #18131084 (external link)
This is a new one on me; thanks for the info!
mwsilver
Gallery: 54 photos
Joined Oct 2011
Sep 17, 2016 14:50 |  #15
Snydremark wrote in post #18131099 (external link)
You didn't see my additional edit with an example.
"For instance, if originally the center focus point was on a person's right eye, after distortion correction the eye may have shifted and the display of the focal point might now be on the nose or between the eyes. The image is no longer the one you took so the focus point locations are no longer relevant."
Remember the lens distortion correction affect things like pincushioning. I personally turn that feature off in-camera and apply lens distortion correction in post. But. if you shoot jpegs and do very little post processing it may be useful to turn it on.
Mark
7,596 views & 8 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1427 guests, 113 members online
