FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 19 Sep 2016 (Monday) 06:08
Portatble external drives suggestions
Rob-P
Joined Jun 2012
Post edited over 7 years ago by Rob-P.
Sep 19, 2016 06:08 |  #1
HI,
Any suggestions for this one?
I have an EOS 5D MKII I default to RAW + JPG shooting, the largest cards I use are 16GB or 32GB Sandisks or equivalents.
Has anyone any knowledge of a portable Hard drive that can download direct from the camera without a PC / laptop being involved? Is there even such a thing?
(I think there may be, as recently I saw someone on a tourist train loading images from a phone, to an external drive) I was not sure they spoke English / Spanish so could not ask technicalities.
I have seen other similar posts but most relate to phones. All I want to be able to do ( simply put) is to 'plug' in an external drive / device and have it backup the camera contents, belt and braces)
Thanks in advance. McP
John ­ from ­ PA
Joined May 2003
Sep 19, 2016 07:06 |  #2
Not sure if a "direct" connection can be accomplished but there are an abundance of drives that have a plug in slot for a memory card, which then has its contents written to a hard drive. B&H summarizes there offerings at https://www.bhphotovid​eo.com …rage/ci/3369/N/​4000227848 (external link).
Note that there is a device specifically by Canon and for Canon cameras. The reviews are not great however and on the surface it seems hard to set up. But some of the reviews are old and things may have improved.
sipowicz
Joined Jan 2013
Sep 19, 2016 19:26 |  #3
Are you looking to then format the cards and keep shooting? If so, I would be very careful when backing up "blind".
If you are just wanting to make another backup and keep the files on your cards, that would be the safer way to go.
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Sep 19, 2016 19:28 |  #4
Rob-P wrote in post #18132728 (external link)
HI,
There's a portable WD hard drive that takes SD cards and has battery and wifi. You insert the SD card, it copies it, you go back to shooting.
Very best,
John ­ from ­ PA
Joined May 2003
Sep 19, 2016 21:08 |  #5
MalVeauX wrote in post #18133673 (external link)
Very best,
https://www.bhphotovid​eo.com …my_passport_wir​eless.html (external link)
Read the reviews before you take the leap.
Ming-Tzu
Joined Apr 2012
Sep 19, 2016 22:04 |  #6
Are there any back up devices that takes SD and CF cards?
<insert gear here>
John ­ from ­ PA
Joined May 2003
Sep 20, 2016 06:59 |  #7
Ming-Tzu wrote in post #18133803 (external link)
Many do, including the Canon solution. Check the link I provided in reply #2 above.
Ming-Tzu
Joined Apr 2012
Sep 20, 2016 07:04 as a reply to  @ John from PA's post |  #8
Thanks!
Checked it out and not really a portable device because it looks like it's required to be plugged in. I was looking for a SD/CF solution I could use in my car as a backup for my cards, when I don't have a computer handy. Such as on a road trip or camping trip.
The search continues.
<insert gear here>
John ­ from ­ PA
Joined May 2003
Post edited over 7 years ago by John from PA.
Sep 20, 2016 07:39 |  #9
Ming-Tzu wrote in post #18134056 (external link)
Thanks!
Check the Nexto line at the link. Many of them have internal batteries and can also be powered from a USB. Many cars these days have USB power outlets built into the dash and at last resort you can use the cigarette lighter with a USB adapter.
I think the Nexto's also can directly sync to an external USB hard drive should another copy be needed as a backup.
Personally, at the price of memory, I would just buy some extra cards and be done with it. There is little market for these types of devices and the prices (IMO) are not likely to drop much, if at all. A very small marketplace generally means high prices.
Rob-P
Joined Jun 2012
Sep 21, 2016 04:09 |  #10
Thanks to all for suggestions, I've got some ideas now. Also noted. I would NOT backup Blind and format CF cards for re-use whilst away on vacation. That is asking for it. It was more of a belt and braces thing. Thanks, All.
McP.
2,394 views & 0 likes for this thread, 5 members have posted to it.
1505 guests, 130 members online
