Thread started 19 Sep 2016 (Monday) 08:26
Filenames
Josilou
Sep 19, 2016 08:26 |  #1
When I import pictures into lightroom, even though it is changing them into .dng's the filename and number assigned on my camera both seem completely disregarded and LR recognises it as
untitled-shoot-001.dng and so forth.
I've only been using LR for a few weeks so realise it is probably a setting I haven't found or something I am doing wrong, but I'm struggling to find it and wondering if there is a way to synchronise the filenames assigned on camera to LR or whether it really is a case of having to rename everything. I can see how to create filenames etc. on LR, it's just the synchronising.
TIA for any suggestions
Canon EOS 70D EOS Digital Rebel XT / EOS 350D / Kiss Digital N EOS 5D Mark III | Canon EF 50mm f/1.8 II EF 24-105mm f/4L IS USM EF-S 18-135mm f/3.5-5.6 IS STM EF-S 10-18mm f/4.5-5.6 IS STM EF-S 18-55mm f/3.5-5.6 II EF 100-300mm f/4.5-5.6 USM EF 35-80mm f/4-5.6 III USM EF 85mm f/1.8 USM EF 100mm f/2.8 Macro USM EF 17-40mm f/4L USM | Sigma 70-200mm f/2.8 EX DG APO OS HSM | Canon Speedlite 430 EX
Mike
ugly when I'm sober
Gallery: 51 photos
Sep 19, 2016 08:36 |  #2
You can change the file-naming on import.
Just head over to the File Renaming section and open up the options.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/3/LQ_814678.jpg
Image hosted by forum (814678) © Mike [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/09/3/LQ_814679.jpg
Image hosted by forum (814679) © Mike [SHARE LINK]
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
pknight
Gallery: 39 photos
Joined Feb 2006
Sep 19, 2016 08:38 |  #3
You must have changed the import settings somehow to rename the files. I have been importing and converting to DNG for years, and LR always uses the camera's filename when naming the imported images.
On the Import screen, on the right side, is a menu labeled "File Renaming." Make sure that the "Rename Files" box there is not checked.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
nathancarter
Gallery: 32 photos
Sep 19, 2016 08:42 |  #4
Just chiming in, there is definitely a way to do it so that it preserves the original file number, using the "Custom" renaming. I'm not in front of Lightroom right now so I'll try to remember off the top of my head. I believe you use the "filename number suffix" in your custom file renaming to preserve the file number. For instance, mine is (I think)
(Custom text)_(YYYYMMDD)_(File​name number suffix 0000).dng
So if I type in "Vacation" in my Custom Text box, it'll rename the file Vacation_20160831_0452​.dng where the original file was numbered something like IMG_0452.dng
https://www.lightroomp​resets.com …e-your-files-in-lightroom (external link)
If you use "sequence" number it'll always start at 1 every time you import. Or 0001, depending on which sequence format you choose.
It's important to note that the little preview of the filename will always start at 1 or 0001 until you actually start the import, because it doesn't look at the actual filename while you're setting up the custom file renaming.
pknight
Gallery: 39 photos
Joined Feb 2006
Sep 19, 2016 08:45 as a reply to  @ nathancarter's post |  #5
My impression was that the OP wanted to just use the name/sequence number assigned by the camera. If not, the other renaming options mentioned above will allow other convention. If all that is desired is the camera name/number, just uncheck the rename box.
Josilou
Sep 19, 2016 09:17 |  #6
Thank you all, yes pknight, you are right :) I just want to use the name and number assigned by the camera - the reason is because I am trying to sort out a 'smooth' workflow haha, whereby I'm wanting to import photos from my camera, save immediately to dropbox etc. and so then when I'm importing them into LR for editing, I would rather know without needing to remember that they maintain the same filenames in terms of name and number, even if it's just IMG_0765 or whatever.
I will search for the rename box - can't see it on the import screen but I think it's exactly something like that that I must have accidentally ticked.
Thanks.
Mike
ugly when I'm sober
Gallery: 51 photos
Sep 19, 2016 09:19 |  #7
Josilou wrote in post #18132896 (external link)
Thanks.
It should be there if you select "Copy as DNG", "Copy", or "Move" but not if you select "Add".
Gear
UK South Easterners
Josilou
Sep 19, 2016 09:29 |  #8
Got it, thanks. It seems so dopey, but I hadn't seen the full importing screen, so hadn't seen that menu on the right hand side at all. I've been importing just using the very small pop up option.
A whole new world of choices and control. Thank you !
3,216 views & 5 likes for this thread, 4 members have posted to it and it is followed by 3 members.
Filenames
629 guests, 117 members online
