Thread started 19 Sep 2016 (Monday) 15:24
Sigma optical stabilization on tripod
eddieb1
Joined Apr 2013
Sep 19, 2016 15:24 |  #1
Does the stabilization in Sigma lenses need to be turned off when on a tripod, specifically when using a gimbal head?
Bassat
"I am still in my underwear."
Joined Oct 2015
Sep 19, 2016 15:26 |  #2
I used to have a 70-200 OS. For that lens, yes, turn off the OS when on a tripod.
John ­ from ­ PA
Joined May 2003
Sep 20, 2016 08:01 |  #3
For most lenses, this is a good idea. The exceptions are the lenses that have various "modes" on the IS switch. Some modes can handle specific situations. It is also a good idea to look at your situation. As an example, even though I have a relatively high end tripod, in some situations (like gusty winds) I find I can improve my image leaving IS ON. Experiment if need be, digital film is cheap.
eddieb1
Joined Apr 2013
Post edited over 7 years ago by eddieb1.
Sep 20, 2016 09:26 |  #4
Would treating a gimbal head like a ball head be appropriate? I'm new to gimbal heads and not sure, exactly, how to use one. I plan on working, a lot, with it, but would like some guidance please?
ebiggs
Gallery: 24 photos
Joined Oct 2012
Sep 20, 2016 20:49 |  #5
eddieb1 wrote in post #18133373 (external link)
Does the stabilization in Sigma lenses need to be turned off when on a tripod, ...
I seem to find it makes little difference. I am sure at times it may hurt but at times it helps. Just like how it is when you hand hold it.
G1x, EOS 1Dx, EOS 1D Mk IV, ef 8-15mm f4L,
ef 16-35mm f2.8L II, ef 24-70mm f2.8L II, ef 70-200mm f/2.8L IS II,
Sigma 150-600mm f5-6.3 DG OS HSM Sport
*** PS 6, ACR 9.3, Lightroom 6.5 ***
ebiggs
Gallery: 24 photos
Joined Oct 2012
Sep 20, 2016 20:50 as a reply to  @ eddieb1's post |  #6
What lens? A gimbal is at its best with bigger teles.
eddieb1
Joined Apr 2013
Sep 20, 2016 23:12 as a reply to  @ ebiggs's post |  #7
Sigma 150-600C
BigAl007
Gallery: 556 photos
Sep 21, 2016 13:46 |  #8
Well generally when tracking using a gimbal head you will have the system lose, so that you can track, so you will be holding onto the camera/lens combination and imparting some unwanted motion, so yes you will want to most probably be using mode 2 OS. It's what I would do if I were using one for my one.
Personally for airshows, where I need to be able to swing the pan through 180 degrees as the aircraft pass across the front of me I always found using a tripod difficult. With that much rotation I used to find that I needed to walk around the thing. now I'm in a wheelchair there is zero chance to that. Back in the late 70's I discovered a shoulder stock system that I started using with a 400mm lens. This was of course pre image stabilisation, or even AF for that matter, and I found it very useful. Unfortunately I lost the thing over the years in some house move or other. When I got my 150-600 C I got hold of one of those cheap chinese made 15mm rail systems that they build video rigs from and built a shoulder pod out of that. I use it with a remote release taped to the front handle. It makes life really easy when you have a very large change in direction to deal with.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/2/LQ_775622.jpg
Photo from BigAl007's gallery.
Image hosted by forum (775622)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/2/LQ_775623.jpg
Image hosted by forum (775623)
I was getting regular keepers shooting at 600mm and 1/160s plus applying a 50% crop on my 50D using this rig, the FoV is equivalent to using a 900mm lens (1440mm 35mm FoV equivalent).
Alan
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 22, 2016 20:15 |  #9
If your hand is on the camera while you are taking photos then (maybe because I mostly do landscapes) I personally do not consider that to be 'on a tripod'. If you mean 'hands off' on a tripod, then I would turn off IS.
I used to have this lens and unless I was panning very quickly I left IS on because it helped be keep the AF point on the subject. I did not notice any problems with the IS when moving the lens fairly rapidly - e.g. following BIF.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
ebiggs
Gallery: 24 photos
Joined Oct 2012
Sep 26, 2016 01:08 |  #10
Why not just give it a try? I think you will be surprised at whether you can see or tell the difference most of the time.
4,525 views & 1 like for this thread, 6 members have posted to it.
666 guests, 121 members online
