On a canon camera,,which one do you rate best ?? and why ??Useing on a SL1 and 50D?
I want a all in one lens,,i know NOT good in low light,,but NOT want to buy a P&S supper zoom.. Thanks Ron
RonnieH Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info Post edited over 7 years ago by Ronnie H. | Sep 21, 2016 07:19 | #1 On a canon camera,,which one do you rate best ?? and why ??Useing on a SL1 and 50D?
Qlayer2 OOOHHH! Pretty Moth! More info | Sep 21, 2016 07:30 | #2 Does it have to be an all in one? The Canon 18-55 STM and 55-250 STM weigh almost nothing, have excellent IS, and will get you much higher quality at a more reasonable price than a single 18-300. 18-55 STM can be had like new out of a kit for $80 or so, and the 55-250 STM refurbed from Canon is $129.
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Sep 21, 2016 08:04 | #3
Sep 21, 2016 11:22 | #4 If you had the STM version of the 18-135 and did not like it (assuming your dislike had nothing to do with its lack of range to zoom out to 300mm!), then I hardly think getting a consumer lens of the types you suggest will please you.
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Sep 21, 2016 13:19 | #5 When I tried the Tamron 16-300 on my 50D I was very very impressed, I thought it was pretty much as good or better than as many other consumer grade lenses with much shorter ranges, and of course going all the way out to 16mm is quite significant in FoV terms, although only 2mm that's a full 11% wider so is pretty noticeable. I think it would make a great travel combo with an SL1/100D for situations where you absolutely needed that range of focal lengths, and did not have the possibility of being able to change lenses. It's a lot of money just for the luxury of not changing lenses though, especially given that you already have the 10-18/18-55/55-250 STM trinity that will get you pretty much the whole of that range, and the 10-18 UWA allows wider than the single lens, which you can fix in post from a single exposure. Cropping from 250 to 300mm FoV in post is not going to generally significantly affect quality.
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Sep 22, 2016 04:21 | #6
Sep 22, 2016 09:43 | #7 Ronnie H wrote in post #18136356 Thanks for all your response,,, I think Qlayer2 had a great idea,,use what we have and save the $600,,my research showed the Tamron just a Tad bit better than the sigma,,,but we have another idea,,wife and i each have a Canon SL1,,so one of the wide lens on one and the 55-250 STM on the other and still a light weight pkg,! we also each have a Canon 50D and some big glass ??Thanks Ron Sounds like you have your solution. so that is great. For the benefit of others, I have the Tamron 16-300, and it has not disappointed in those situations where I want/need to use a single lens. I stop it down a bit to f/8, and get very good results. I use other lenses much more often, but the wide range does pay off often enough to keep it in my bag. Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
| Latest registered member is semonsters 1099 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
