Thread started 24 Sep 2016 (Saturday) 08:27
5D4 flash compatability - Yongnuo 600EX-RT
KatManDEW
Gallery: 23 photos
Joined Jan 2005
Sep 24, 2016 08:27 |  #1
Is the 5D4 not compatible with the Yongnuo 600EX-RT flash? I just tried it yesterday and get nothing but blown exposures in ETTL or manual mode. The 5D4 says incompatible flash when I try to change anything in the flash menu.
notastockpikr
Joined Aug 2011
Sep 24, 2016 09:26 |  #2
I think the comment should be that the Yongnuo flash is not compatible with the 5D IV and not that the 5D4 is not compatible. Maybe Yongnuo has a fix.
Wilt
Post edited over 7 years ago by Wilt.
Sep 24, 2016 09:32 |  #3
Are you certain that the flash is detecting that the camera is eTTL camera, so that it is choosing the ETTL mode?
Flash may default to film-based TTL mode which would cause all exposures to be Overexposed.
You may need to make sure that the camera is On and functioning when you mount the Flash and select the mode, for it to go into ETTL rather than TTL.
KatManDEW
Gallery: 23 photos
Joined Jan 2005
Sep 26, 2016 16:54 |  #4
Wilt wrote in post #18138760 (external link)
The 5D4 says incompatible flash attached when I try to change anything in the flash menu.
The problem seems to be with wireless mode. I can use a 600EX-RT on the camera and it appears to work correctly, although the 5D4 says incompatible flash attached when I try to change anything in the flash menu.
Bill ­ Emmett
Joined May 2012
Sep 27, 2016 13:47 |  #5
I tried mounting one of my 565EX flashes on my 5D MIV. I had no problem. I then mounted one of my 622C triggers on the hotshoe, set it to flash my 565EX on a 622C, and tried it, all worked fine. I got no messages on the camera, nor the flash. Sorry I don't have a 600 flash.
New Canon EOS 5D Mark IV, Canon EOS 7D Mark II, Canon EOS 50D, Canon 7D Classic, Canon 6D, Canon EF 70-200 f4L USM with IS, Canon 40mm pancake, Canon EF 50mm 1.8, Canon EF-S 10-22mm wide angle, Canon EF-S 18-135 IS STM, Canon EF 100mm 2.8L USM Macro, Tamron 18-270mm Dii VC, Tamron SP 150-600mm VC, Tamron SP 24-70mm f2.8 VC USM, Canon EF 16-35 f2.8L II USM, Tamron 2X Tele-Extender, 1.4 Tele-extender
umphotography
grabbing their Johnson
Gallery: 21 photos
Post edited over 7 years ago by umphotography.
Sep 27, 2016 14:31 |  #6
I had to ditch my Youngnuo 622C triggers
Non compatible with the 1Dx2
The 568EX11 does work on camera but not with triggers
Tried for a month to see if youngnuo had an update---- ZERO RESPONSE
I have purchased new flashes from Godox
568C all compatible with 1Dx2 as well as all Godox triggers and strobes compatible
Fed up with Younnuo's crappy customer service
Buy Godox it works
Mike
www.umphotography.com (external link)
Facebook (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Sep 27, 2016 15:23 |  #7
umphotography wrote in post #18141977 (external link)
Buy Godox it works
and is updated often.
CDS' HOT LINKS
George ­ Zip
My neighbours are looking at me a bit strangely
Gallery: 31 photos
Joined Aug 2015
Sep 28, 2016 07:17 |  #8
Are Gordox's as good as Canon Speedlite's?
umphotography
Gallery: 21 photos
Sep 28, 2016 18:44 |  #9
George Zip wrote in post #18142596 (external link)
My Opinion ???
ETTL behaves better on the Godox flash units than it does on my 580EX11 or the 600 I tested against
ETTL is far far far more accurate on the Godox units than it is on the Canon units.....BY A MILE
The menu is easier to use on the Godox V860 than it is on the 600's
Output is the same
Build goes to canon but I would not say by a lot
Flip white card on the Godox is a piece of crap....will break off with use..I put up with it because I use a demb flip anyway
Costs go to Godox-- 175.00 v/s $550.00--- Another No Brainer
It you buy it from Cheetahstand you can get it repaired cheaper than you can through CPS with a canon flash when you break off the hot shoe
Ability to use with your other Godox flashes........Goes to Godox
Ability to use older flash units on the Godox system v/s canon systems :-P:-P:-P:-P Canon is a joke
Ability to trigger with other lights.....goes to Godox
Godox has the best trigger system on the Market. Nothing can touch it. I can trigger a 600BM, a CL360EX and a speedlight from the same trigger and shoot in Full F/16 light with no issues and I can shoot at F/2.0............Never gonna Happen with Canon flash equipment
Canon lost a loyal customer. Godox kicked Canon's Butts anyplace you can test the Godox products at against the Canon flash products
Its simply a No Brainer. Godox wins by a mile and then some
Mike
George ­ Zip
Gallery: 31 photos
Joined Aug 2015
Sep 28, 2016 19:06 |  #10
umphotography wrote in post #18143086 (external link)
My Opinion ???
Output is the same
Thank you.
I only have one speedlite, and have been considering getting some more as I want to learn more about strobe photography.
So I will look into these.
Algol ­ Paradox
Joined Jul 2012
Oct 06, 2016 09:39 |  #11
KatManDEW wrote in post #18141250 (external link)
Have you tried the recent 1.9.0 firmware that supposedly improves compatibility with new cameras? I gather there are also some similar updates for the 622s...
KatManDEW
Gallery: 23 photos
Joined Jan 2005
Nov 20, 2016 10:48 |  #12
Algol Paradox wrote in post #18149773 (external link)
Thanks for the reply! Where can I obtain that firmware?
KatManDEW
Gallery: 23 photos
Joined Jan 2005
Nov 20, 2016 21:06 |  #13
I found the firmware. Different firmware files, and firmware updater apps, for the flashes versus the transmitter...
The system seems to work correctly with my 5D4 now, although I still get a "Incompatible flash attached" message on the 5D4 sometimes.
DaviSto
... sorry. I got carried away!
Gallery: 56 photos
Joined Nov 2016
Nov 29, 2016 14:51 as a reply to  @ umphotography's post |  #14
Strange ... no problem at all with either the 568EXii or the 622C triggers on the 5D iv. They work fine, exactly as they do on my old 5Dii.
David.
Comment and (constructive) criticism always welcome.
DaviSto
Gallery: 56 photos
Joined Nov 2016
Nov 29, 2016 16:27 as a reply to  @ KatManDEW's post |  #15
Same for me ... but no incompatibility message ... sweet as a nut.
David.
16,594 views & 7 likes for this thread, 12 members have posted to it and it is followed by 8 members.
1431 guests, 139 members online
