Thread started 28 Sep 2016 (Wednesday) 17:37
Is this a dirty sensor?
Orias
Gallery: 19 photos
Joined May 2011
Sep 28, 2016 17:37 |  #1
Hi guys,
I am pretty sure that my sensor is dirty (very), but I wanted to check as I haven't noticed this before. I was out taking a few shots today at a local airfield, and I noticed the following:
In this image, the sky is full of horizontal lines that are very VERY visible (it's not a good shot, obviously, but there are others like this). This was taken at f/32:
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i876.photobucke​t.com …/IMG_1396_zps7h​lm5l1s.jpg (external link)
on photobucket
And another image, same day, same lens, same conditions .. but at f/5.6, where the lines are not visible:
http://i876.photobucke​t.com …/IMG_1673_zps28​swcui6.jpg (external link)
on photobucket\
I did try and clean my sensor a month or so ago (and I've done it before in the past), and this does look like dry "water" lines on the sensor, maybe? I've used the camera a lot since I did this, but this is the first time I've noticed these lines ... but also the first time I've ever really gone above f/10 or so.
Did I just screw up the sensor cleaning? And is it just a case of going back in there and doing it again (but properly, of course :p)
Thanks,
James
Canon EOS 70D + Canon EF 70-300 F4-5.6L IS USM + Canon EF 100mm f/2.8 Macro USM + Canon 10-18mm IS USM, Canon 18-135mm, Canon 50mm 1.8, Canon 55-250mm IS + Canon Speedlight 430 EXII
My Site - Arup Photography (external link)
500px - http://500px.com/arnie​arup (external link)
Flickr - James Flickr (external link)
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Sep 28, 2016 18:00 |  #2
Yeah, looks like your swab skill need some work there mate.
Getting better at this - Fuji Xt-2 - Fuji X-Pro2 - Laowa 9mm - 18-55 - 23/35/50/90 f2 WR - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Sep 28, 2016 18:01 |  #3
Or just don't shoot at f32.
MalVeauX
"Looks rough and well used"
Gallery: 1696 photos
Joined Feb 2013
Sep 28, 2016 18:04 |  #4
Yup, looks dirty from dried fluid on the sensor.
Very best,
Orias
Gallery: 19 photos
Joined May 2011
Sep 28, 2016 18:32 |  #5
FarmerTed1971 wrote in post #18143050 (external link)
Can't argue with you there. I'll try it again.
I wasn't intending to shoot at f/32, I just had it in "Shutter Priority" mode for some ground shots, and forgot to switch it back. It was pretty bright up there, so the camera just decided to whack it up to f/32. Although I'm glad it did as I wouldn't have noticed this otherwise!
Cheers!
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Sep 28, 2016 19:40 |  #6
Set the camera to not go higher than f22 (or 16) in auto modes.
Trvlr323
Sep 28, 2016 20:03 |  #7
You might not have done such a bad job. We didn't see what it looked like before ;) Sensor cleaning is pretty easy. It won't take you more than a few times to get the hang of it. Some particles really bond to the low pass filter and can be quite tough to remove. I recently picked up a box of relatively inexpensive VSGO swabs and I found their cleaning solution worked better than eclipse. I usually swab once and go after any remaining particles with a sensor pen.
Here is a link that you might find useful.
http://www.cleaningdig​italcameras.com (external link)
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Bassat
"I am still in my underwear."
Joined Oct 2015
Sep 28, 2016 20:21 |  #8
FarmerTed1971 wrote in post #18143121 (external link)
Pretty sure the 70D can't do that.
gjl711
According to the lazy TF, My flatulence rates
Sep 28, 2016 20:41 |  #9
When you get lines like that, it's a indication that you are using too much fluid or the wrong type of fluid. When wet cleaning the swab should be barely damp.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Sep 28, 2016 20:49 as a reply to  @ Bassat's post |  #10
Bummer, really?
BigAl007
Gallery: 542 photos
Sep 29, 2016 04:15 |  #11
I will say this, your shutter speed in the first shot was far more appropriate for the subject than the one used in the second shot. When photographing aircraft with propellers, such as with this Spitfire I won't go above 1/160s to ensure a decent amount of prop blur, frozen props make the plane look like it is about to fall out of the sky. I notice you had ISO 200, but even ISO 100 would still only get you f/22, moving to 1/160 would then just get you 1/3 stop more on the aperture, which will still not produce great results, and with the sky as a background is likely to show up every spot of dirt on your sensor. If you are likely to be shooting in these sorts of conditions a lot I would suggest investing in some good quality ND filters. I would think that a 1 and 3 stop, or even 2 and 4 stop pair of filters would give the perfect options. I really couldn't care too much about ISO 1 Million, but having native base ISO of 25 would be great. 25 to 6400 would suit me pretty much as a speed range.
Alan
My Flickr (external link)
1,916 views & 0 likes for this thread
Latest registered member is Knoxville_Photographer
1559 guests, 346 members online
