Thread started 01 Oct 2016 (Saturday) 15:38
Battery caused a problem with 7D Mark II
Ralpho
Oct 01, 2016 15:38 |  #1
I was shooting a soccer game today when my camera suddenly stopped working. The number that shows remaining shots was missing. Camera wouldn't focus or fire. Image review didn't work. Menu didn't appear when Menu button was pressed. All other display numbers appeared normal.
I tried various fixes, like checking switches on lens, disconnecting and reconnecting lens, cycle power switch, take CF card out and put it back in and changing modes. I left the game and went home, where I remembered to try my other battery. I swapped them out, and the camera works normally.
Has anyone else had this problem? Know the cause? Your insight is sought and appreciated.
PJJ205
Joined Aug 2015
Oct 01, 2016 15:57 |  #2
What brand battery? OEM or third party?
mwsilver
Gallery: 54 photos
Joined Oct 2011
Oct 01, 2016 16:33 |  #3
Ralpho wrote in post #18145556 (external link)
For what its worth, I always carry a spare battery.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
Ralpho
Oct 01, 2016 18:48 as a reply to  @ PJJ205's post |  #4
Canon battery.
Bassat
"I am still in my underwear."
Joined Oct 2015
Oct 01, 2016 19:52 |  #5
I've had two Canon cameras act funny when the battery gets low, say below 10%. I haven't had any problems since I switch batteries at 20% now.
Trvlr323
Oct 01, 2016 20:02 |  #6
Haven't had this happen to me but I hear about it happening occasionally.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Beekeeper
Gallery: 46 photos
Oct 02, 2016 00:17 |  #7
The battery that originally came with my 7D2 wouldn't work. Canon exchanged it right away.
Zach--C&C is welcome on my photos
https://www.flickr.com​/photos/46367607@N06/ (external link)
7DI Body Gripped|7DII Gripped|EF 85mm1.8|EF 50mm1.4|EF 100mm2.8L IS Macro|EF-S 10-22mm|EF 400mm5.6L|430EXII|580E​XII
Ralpho
Oct 02, 2016 05:13 as a reply to  @ Bassat's post |  #8
My battery had 50-75 percent of its charge left when camera stopped working.
bildeb0rg
Gallery: 821 photos
Oct 02, 2016 07:24 |  #9
If your charger has a conditioning function (total discharge then recharge) try that and see how it goes...
Bassat
Joined Oct 2015
Oct 02, 2016 08:15 |  #10
bildeb0rg wrote in post #18146010 (external link)
Better advice is to throw away the battery. They are way too cheap to chance frying $1500 camera with a defective one.
gjl711
Oct 02, 2016 09:08 |  #11
Not good advice for a Lithium Ion battery. Li batteries do not like to be fully discharged.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Bassat
Joined Oct 2015
Oct 02, 2016 09:35 |  #12
gjl711 wrote in post #18146073 (external link)
If this is true, why does Canon build this functionality into the 1DIII/1DIV/1DX/1DXII battery chargers? As mentioned above, and in Canon white papers, this extends the life of the Li-ion batteries that come with these cameras.
Wilt
Post edited over 7 years ago by Wilt. (7 edits in all)
Oct 02, 2016 11:47 |  #13
Bassat wrote in post #18146086 (external link)
I take Canon technical 'advice' with a grain of salt...after all, when every other flash manufacturer in the world makes flash units with flash photosensor Auto mode that results in precise exposures, Canon invented the 430EXII and 580EXII and 600EX-RT that all underexpose by -2EV when in External (photosensor) mode, and created cameras (Canon 20D and 30D) that forced you to use FEC +1EV in order to take photos with flash exposed the same as ambient-only exposure mode! Neither behavior seems logical. :-)
As for lithium ion care: http://www.techrepubli​c.com …lithium-ion-battery-life/ (external link)
"3: Allow partial discharges and avoid full ones (usually)
Unlike NiCad batteries, lithium-ion batteries do not have a charge memory. That means deep-discharge cycles are not required. In fact, it's better for the battery to use partial-discharge cycles.
"There is one exception. Battery experts suggest that after 30 charges, you should allow lithium-ion batteries to almost completely discharge. Continuous partial discharges create a condition called digital memory, decreasing the accuracy of the device's power gauge. So let the battery discharge to the cut-off point and then recharge. The power gauge will be recalibrated.
...but this has nothing to do with battery LIFE, only the power guage recalibration for improved accuracy.
"4: Avoid completely discharging lithium-ion batteries
If a lithium-ion battery is discharged below 2.5 volts per cell, a safety circuit built into the battery opens and the battery appears to be dead. The original charger will be of no use. Only battery analyzers with the boost function have a chance of recharging the battery.
"Also, for safety reasons, do not recharge deeply discharged lithium-ion batteries if they have been stored in that condition for several months.
"5: For extended storage, discharge a lithium-ion battery to about 40 percent and store it in a cool place
I've always had an extra battery for my notebook, but it would never last as long as the original battery. I know now that it's because I was storing the battery fully charged. That means oxidation of lithium-ion is at its highest rate. Storing lithium-ion batteries at 40 percent discharge and in the refrigerator (not freezer) is recommended"
Bassat
Joined Oct 2015
Oct 02, 2016 11:51 |  #14
Wilt wrote in post #18146206 (external link)
I take Canon technical 'advice' with a grain of salt...after all, when every other flash manufacturer in the world makes flash units with flash photosensor Auto mode that results in precise exposures, Canon invented the 430EXII and 580EXII and 600EX-RT that all underexpose by -2EV when in External (photosensor) mode, and created cameras (Canon 20D and 30D) that forced you to use FEC +1EV in order to the photos with flash to be exposed the same as ambient-only exposure mode! Neither behavior seems logical.
Scratching my head and trying to figure out what any of that has to do with lithium-ion battery chemistry.
Wilt
Oct 02, 2016 11:56 |  #15
Bassat wrote in post #18146211 (external link)
The flash information was for humor. I added lithium ion care info, after I mistakenly posted the message before I had completed it!
5,064 views & 1 like for this thread, 12 members have posted to it and it is followed by 4 members.
1205 guests, 129 members online
