It has been a while since i have posted in here. I just got the Canon 7D MK II so i figured why not, please give some CC. I think this is a great way to learn.
IMAGE LINK: http://www.framedmoments.net/Photos/Landscapes/i-n9CVxC2/AMudhog79 Member More info Post edited over 7 years ago by Mudhog79. | Oct 03, 2016 21:26 | #1 It has been a while since i have posted in here. I just got the Canon 7D MK II so i figured why not, please give some CC. I think this is a great way to learn. IMAGE LINK: http://www.framedmoments.net/Photos/Landscapes/i-n9CVxC2/ACanon EOS 7D Mark II, EFS 55-250mm IS, EF 50mm f/1.4, EFS 17-55 mm f/2.8 IS, 430 EXII Speedlite, Fiesol 3441T, Photo Clam PC-40NS
Oct 03, 2016 22:16 | #2 They both look a little overexposed to me. You might try a graduated darkening of the lower 1/3 in #1 and an overall darkening of #2. -- Image Editing OK --
BigAl007 Cream of the Crop 8,118 posts Gallery: 556 photos Best ofs: 1 Likes: 1681 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Oct 04, 2016 06:10 | #3 I agree with the overexposure as well. I would consider pulling the highlights way down in the RAW converter, assuming you are using one that allows separate control of highlights/midtones/shadows, as a first step. If using ACR/LR as well as pulling the highlights you could probably also drop the midtones (Exposure slider) a bit to put you much closer to where you want to be, without necessarily needing to ad a filter.
joedlh Cream of the Crop 5,512 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | Oct 04, 2016 17:46 | #4 I see from the exif data on the first one that you used manual exposure. I must assume that you wanted them this light. The one with the cart is more visually interesting. In the other one, there isn't a clear subject. Joe
blaidd Mostly Lurking 17 posts Likes: 1 Joined Jul 2006 More info | Oct 04, 2016 20:31 | #5 The over exposure is a bit much for me. Have you tried turning into B&W and maybe making a bit moody? The first one I have a hard time trying to figure out what's going on with with the cart and kid. Just a bit too wide if that's the subject.
Oct 04, 2016 20:45 | #6 BigAl007 wrote in post #18147848 I agree with the overexposure as well. I would consider pulling the highlights way down in the RAW converter, assuming you are using one that allows separate control of highlights/midtones/shadows, as a first step. If using ACR/LR as well as pulling the highlights you could probably also drop the midtones (Exposure slider) a bit to put you much closer to where you want to be, without necessarily needing to ad a filter. Alan Thanks for the input, i was using LR on these images. I have used the sliders and for whatever reason on the tree picture i had the white cranked way up. When i pull the whites down the areas that were blown out come down. Canon EOS 7D Mark II, EFS 55-250mm IS, EF 50mm f/1.4, EFS 17-55 mm f/2.8 IS, 430 EXII Speedlite, Fiesol 3441T, Photo Clam PC-40NS
Oct 04, 2016 20:49 | #7 joedlh wrote in post #18148472 I see from the exif data on the first one that you used manual exposure. I must assume that you wanted them this light. The one with the cart is more visually interesting. In the other one, there isn't a clear subject. Yes i believe i shot both of these in manual. I wanted the candy cart bright, looking in LR the image is showing some blown highlights only in the moss. The tree picture the subject was the oak tree grove and that is it, just a picture of the oaks with the moss. Canon EOS 7D Mark II, EFS 55-250mm IS, EF 50mm f/1.4, EFS 17-55 mm f/2.8 IS, 430 EXII Speedlite, Fiesol 3441T, Photo Clam PC-40NS
| Latest registered member is zachary24 1427 guests, 112 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
