Thread started 04 Oct 2016 (Tuesday) 16:41
Canon 600EX -RTs Firing Every Other Shot?
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Oct 04, 2016 16:41 |  #1
Hi, guys! I had a wedding Sat. during which the on camera falsh would not fire for every other shot. I know it wasn't low batteries. What would be the first thing you'd check as the culprit?
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
DGStinner
Gallery: 24 photos
Joined Jan 2014
Oct 04, 2016 16:48 |  #2
What power setting were you at? How much time between each shot? Without knowing either of these, my primary guess is the flashes hadn't recycled completely.
Whortleberry
Joined Dec 2011
Post edited over 7 years ago by Whortleberry.
Oct 04, 2016 17:52 |  #3
Michelle Brooks Photography wrote in post #18148419 (external link)
Hi, guys! I had a wedding Sat. during which the on camera flash would not fire for every other shot.
To establish clearly defined starting points:
  1. Was the non-fire precisely every other shot? (i.e. shots 1,3,5,7,9 flash; shots 2,4,6,8 NO flash)
  2. Can you reproduce the behaviour now using the same settings as 'on the day'.
  3. How frequently were you shooting? Every 5 seconds? Every 2 seconds? As fast as you could?
  4. What ISO / aperture / subject distance were you working at?
  5. How do you know that it wasn't low batteries? This is THE most frequent reason and the great majority always absolutely swear it's not low batteries.
Back in the 60s and 70s, 'beating the flash' (ie shooting before the flash had fully recycled) was one of the first things you learned to avoid because flash units even back then had an inhibit circuit which prevented them firing before a certain level of recycling had been reached (usually >85%). Recycling is very much faster nowadays but it's still not at all difficult to 'beat the flash' in the heat of the moment.
To directly answer your question, based on the minimal information provided, the first thing I'd check is "Can I reproduce the symptoms". The answer to that question can take you one of two divergent ways.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
Joined Sep 2009
Oct 05, 2016 09:41 as a reply to  @ DGStinner's post |  #4
I think I was about 1/8 power, very little time between shots, maybe 2 seconds?
Joined Sep 2009
Oct 05, 2016 09:47 as a reply to  @ Whortleberry's post |  #5
I will try re-producing. Yes, it was precisely every other shot. I had charged all batteries the night before, also, after the first incidence of non-firing during the processional, I changed the batteries anyhow before the second incidence. So I truly doubt batteries was the issue. More likely me not allowing enough recycle time. I'll have to check my setting for your 4th questions but I believe for the processional it was f3.5 ISO 640 1/200. Distance to ubject vaired, of course, as the members of the wedding approached.
Nick5
Oct 05, 2016 10:10 |  #6
Michelle Brooks Photography wrote in post #18148939 (external link)
Do you have the Audible Beep enabled. This will beep when flashes have recycled. Like a Metronome, you can follow the tempo.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
AlanU
Gallery: 144 photos
Oct 05, 2016 13:25 |  #7
does this occur with a different flash on that same camera?? It could possibly be a loose shoe on your camera.
Your flash can be getting tired too. Canon repair would look at it and say it's fine even though it is not. I've gone through the same issues with my three 580exii's i've killed. So far my 600ex-rt's have been surviving with perfect performance.
Sounds like there is something going on inside the flash. Wise to have a spare if not 2 spares during a shoot.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
Joined Sep 2009
Oct 12, 2016 13:01 as a reply to  @ Nick5's post |  #8
No, I don't, I don't want anything to call attention to me during weddings but wish I could!
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Oct 12, 2016 13:13 |  #9
At 1/8 it should recycle quickly.
I was having the same problems on Saturday but mine were shooting at or close to Full power.
Should have brought my damned battery packs.
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
3,687 views & 3 likes for this thread, 6 members have posted to it and it is followed by 4 members.
1596 guests, 137 members online
