FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 10 Oct 2016 (Monday) 17:25
What tripod and fluid head do you like for video?
Larry ­ Johnson
Joined Sep 2011
Oct 10, 2016 17:25 |  #1
I need a tripod with leveling base and head for video. What do you like or recommend, hopefully at a reasonable cost.
Here's my expected use and requirements.
Currently have a 7Dii with 100-400 lens. Hope to one day add a small screen, possibly sound mixer, and mic. Might one day also use a longer lens, 500 or 600. I want to keep the rig light, as I might be hiking with it.
The tripod needs a leveling base, will likely be in salty or brackish water from time to time, and needs to spread wide for low shooting. I expect to be sitting on the ground or a stool during most of my filming. Would also like to have ability to switch out the head with a gimbal head for photography shooting.
I currently have a bogen 3021 that was purchased new in the 80s. I find it heavy and hate the thumb locking mechanism, which break too often. I rarely used it for photography. Also don't like the shiney legs.
Thanks.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
SailingAway
Joined Sep 2013
Oct 11, 2016 14:39 |  #2
I don't know of a tripod ideal for your use - the real kicker is frequently running in the mud and water. So, I don't have a definite recommendation, but do consider:
To break things down a bit:
The Benbo Trekker (external link) is great for the muck. The leg joints are at the top instead of the bottom of the legs. Incredibly versatile, low, low, low. It's really for a ball head, though.
Manfrotto has leveling columns (external link) available for several of their "still" tripods. Compact, leave a video head on the leveling column, put a ball head on the original column. A nice solution for dSLR or smaller camcorders.
If you go this route you'll be shopping separately for a video head. Most have fixed counterbalance springs, which are a hassle for light gear, until you put your big lens on, then, if properly matched, they're great.
One of the best newer tripods/heads in a classic video style is the Sachtler Ace series. (external link) Sachtler is one of the few companies to really respond to the small/light trend in video cams or dSLR for video, and their products are highly respected. They've had a few missteps in the Ace line too, but kudos anyway, and supposedly the problems are fixed. If I recall these have adjustable counterbalance.
With a classically styled video tripod you might also invest in a hi-hat, ground pod, or short sticks...
From the upper left corner of the U.S.
Photos, Video & Pano r us.
College and workshop instructor in video and audio.
70D, Sigma 8mm, Tokina f2.8 11-16, Canon EF-S f2.8 17-55, Sigma f2.8 50-150 EX OS, Tamron 150-600VC. Gigapan Epic Pro, Nodal Ninja 5 & R10.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 7 years ago by CyberDyneSystems. (3 edits in all)
Oct 11, 2016 15:03 |  #3
As for leveling tripods, the Induro "Grande" series uses the same industry standard 75mm or 100mm bowl adapters as Gitzo and other brands do.
I have a 2 series and 4 series Induro grand and rate them up with Gitzo for over all toughness.
The 3 series is the sweet spot for most heavy photo shooting, for Video depending on the set up, you might want to go up to the 4.
The older version of the 404 (the one I have) is still available in some places at considerable discount vs. the newest version;
https://www.amazon.com …mbc?ie=UTF8&con​dition=new (external link)
Add these two parts for leveling bowl set up;
https://www.amazon.com …TF8&qid=1476216​148&sr=1-6 (external link)
https://www.amazon.com …fRID=91T6NG56XB​Q2DZ03V7EW (external link)
or;
https://www.amazon.com …TF8&qid=1476216​148&sr=1-1 (external link)
CDS' HOT LINKS
Larry ­ Johnson
Joined Sep 2011
Oct 11, 2016 17:00 as a reply to  @ CyberDyneSystems's post |  #4
Thanks for the suggestions, guys. I'll look into them all.
Ain't Nature Grand!
Larry ­ Johnson
Joined Sep 2011
Oct 11, 2016 20:44 |  #5
would the above two items fit a bogen 3021 to create a leveling base.
Ain't Nature Grand!
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 11, 2016 21:02 |  #6
Larry Johnson wrote in post #18154570 (external link)
I do not think so. The Bowl adapter fits the opening in a Gitzo "Systematic" tripod that is left when the top flat plate is removed. I do not believe Manfrotto makes a tripod that will fit this kind of bowl.
They do however make ones with the bowl built in.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 7 years ago by CyberDyneSystems. (4 edits in all)
Oct 11, 2016 21:04 |  #7
Also, Larry, be aware that this part;
Is only required for "normal" style heads. Many Video specific heads already have the male side of the 100mm/75mm bowl/ball built in.
Example: (pricey one though)
https://www.amazon.com …fRID=0JY7J01V0H​EAD28H9XFB (external link)
Alternatively for smaller more affordable heads/Video rigs, the 100mm bowl parts can be replaced with 75mm parts.
Here's a reasonably priced 75mm ball equipped video head;
https://www.amazon.com …video+head+with​+75mm+ball (external link)
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 11, 2016 21:20 |  #8
Larry, I found this;
http://www.adorama.com …PaajdKY1M8CFUpN​fgodQ7IJxA (external link)
to convert a normal tripod to fit the bowl system.
I'd call Adorama to confirm it will work with your tripod.
CDS' HOT LINKS
Larry ­ Johnson
Joined Sep 2011
Oct 28, 2016 14:41 as a reply to  @ CyberDyneSystems's post |  #9
I ended up buying the manfrotto 502AH video head (with flat base) and will mount on top of an E-image leveling base. Gonna work with my ancient Bogen 3021 tripod for now until I get some experience under my belt. The leveing base came with a 1/4" male thread on top, so I had to put a 3/8" adapter on it. Also, there's no way to lock down the video head to the leveling base. It just screws on and if I'm not careful, it could begin to unscrew if I put lots of drag on my panning to the left. Hope to test it out soon.
https://www.manfrotto.​us …deo-head-flat-base-m-size (external link)
http://www.adorama.com​/iaeia29.html (external link)
Ain't Nature Grand!
Larry ­ Johnson
Joined Sep 2011
Feb 06, 2017 12:22 as a reply to  @ Larry Johnson's post |  #10
Just an update for anyone thinking of buying an Ikan leveling base for their tripod for use with video head. Mine broke after a few months of use. The manufacturer is sending out a replacement today. I suspect these things were meant for use with a video head where there is more side-to-side pressure placed on them versus use with a stills camera. At some point I'll be buying a real video tripod with leveling base.
https://www.adorama.co​m/images/Large/iaeia29​.jpg (external link)
Ain't Nature Grand!
3,392 views & 1 like for this thread, 3 members have posted to it.
1689 guests, 140 members online
