FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 13 Oct 2016 (Thursday) 22:07
Alternatives to the 'Gitzo GT0545T Series 0 Traveler Carbon Fiber Tripod '
Dustman
Post edited over 7 years ago by Dustman. (2 edits in all)
Oct 13, 2016 22:07 |  #1
https://www.bhphotovid​eo.com …5t_series_0_tra​veler.html (external link)
I am looking for a tripod solely for the purpose of traveling and hiking, so size and weight are very important. I already own a full size tripod that I use for work and in the studio.
I was about to purchase the Gitzo in the link above, but I figured I would ask here in the forum for any other suggestions first.
The Gitzo folds to 14.4" and weights in at 2 pounds. It is quite pricy at $700, especially considering this will be my second tripod, and not used for work.
So does anyone have any tripod suggestions, for something that compares in size and weight to this Gitzo?? The choices online give me a headache trying to differentiate. Sooo many models!
I previously used a $100 Joby Gorillipod on my last camping trip, while is was small and light, it had too many issues for me, and I must upgrade.
Thanks everyone for your help in advance!
www.DustinLevine.com (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 13, 2016 22:16 |  #2
I've got an older version of this that I have found to be quite useful;
https://www.bhphotovid​eo.com …004_0_stealth_c​arbon.html (external link)
CDS' HOT LINKS
Dustman
Oct 14, 2016 18:59 as a reply to  @ CyberDyneSystems's post |  #3
Thanks for the recommendation.
I see it is just slightly longer when closed, and a tad heavier........but much cheaper!
I am definitely throwing that into my choices, thanks!
johnf3f
Post edited over 7 years ago by johnf3f.
Oct 15, 2016 15:23 |  #4
I too have a Gitzo Traveller tripod. Mine is the older GT1550T which fold to 14 3/4 inches.
Depending on your personal requirements I would suggest that a 1 series might be better. It will cost a bit more and weigh slightly more but will be more rigid and taller though still nice and short when folded:
https://www.bhphotovid​eo.com …5t_series_1_tra​veler.html (external link)
If you don't mind a little extra length then a 4 section version will be even more rigid.
Ideally I would suggest a used tripod as my Traveller cost £140 ($170).
Life is for living, cameras are to capture it (one day I will learn how!).
Dustman
Oct 22, 2016 18:43 as a reply to  @ johnf3f's post |  #5
That 1555 link you just sent is very interesting. While it does weight slightly more and is taller........it actually folds up smaller! Wow!
So now I would have to consider choices of weight verse size.
Do I take a tripod that folds up smaller but weights more, or a lighter tripod that folds up longer?
Thanks for the recommendation Jognf3f
cccc
Gallery: 18 photos
Oct 23, 2016 09:59 |  #6
I am currently exploring options in this area as well, I have a 3 week trip to Thailand planned and don't want to be inconvenienced with a large tripod. I came across this write-up from B&H, you may find it helpful: https://www.bhphotovid​eo.com …ying-guide/travel-tripods (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Oct 23, 2016 10:46 |  #7
I've got the MeFoto Globetrotter in aluminum and it's surprisingly stable for such a small unit. When I was looking for a travel unit, I played with the CF and Aluminum side by side, and found that the CF version wasn't enough lighter to warrant the cost difference; but I've used this tripod for everything up to my 7DII + 100-400, and while it takes maybe a second or two longer to settle out it isn't too bad. It also compacts down well; if I take the head off the legs, it will *easily* stow in a standard carry-on bag or in my Tilopa BC with the rest of my camera gear.
Dustman
Oct 23, 2016 11:15 as a reply to  @ cccc's post |  #8
Hey CCCC, funny thing I am looking to upgrade my travel tripod because of my recent trip to Thailand!! I spent a month in Thailand and Vietnam recently, and took along this.........
https://www.bhphotovid​eo.com …lapod_Focus_Fle​xible.html (external link)
https://www.bhphotovid​eo.com …2_494_Mini_Ball​_Head.html (external link)
While it got the job done, and I do like it, there was too many instances I would have preferred a ''normal'' tripod.
And looking at the specs. This tiny Joby with Manfrotto head..........it the same exact length and weight as the Gitzo I am looking at!
So the Gitzo would actually be no inconvenience on a trip like this. Not at any point did the weight or size of the Joby was issue for me in Thailand, so the Gitzo even being almost full size, would not, since it is almost identical in weight and dimensions when closed.
That all being said, I am now going to sell that combo, if you want it for your trip Haha
gremlin75
Oct 23, 2016 22:06 |  #9
Feisol is worth a look too. They make nice carbon fiber tripods that won't break the bank. I even like their ball heads (after the "safety" feature is removed)
While not marketed as a "travel" tripod I think this comes fairly close to the gitzo you linked to. A little over an inch longer when folded but a little lighter then the gitzo, larger diameter leg tube (21.7mm vs 24mm) and almost half the price
https://www.bhphotovid​eo.com …2_rapid_carbon_​fiber.html (external link)
Feisol makes several other tripods that they market as travel tripods that might be good to look at also.
Dustman
Oct 24, 2016 00:07 as a reply to  @ gremlin75's post |  #10
That looks really great actually, I have never come across that model before.
It is by far the most interesting of everything I have come across in comparison of that Gitzo. I'm going to have to take a trip to B&H and look at that in person. Thanks so much man!
johnf3f
Oct 24, 2016 15:09 as a reply to  @ Dustman's post |  #11
I can't comment on gremlin75's suggestion as I have never even seen one! However 2 friends have Feisol Tournament tripods (a bit long when folded) and they are very good with my 300 F2.8 - nice and light too!
Assuming that Feisol traveller models are as well made, as the Tournament models, then they are certainly worth careful consideration!
kaitlyn2004
Oct 26, 2016 20:44 |  #12
I've got the Feisol 3441T traveler tripod which I love, just wish it did indeed fold a bit smaller :). Especially since I RARELY use the reverse-folding manner, it's a bit longer (with ballhead on too) than I was hoping for. Great otherwise!
My Landscape Photography Videos (external link)
My Instagram (external link)
Charlie
Guess What! I'm Pregnant!
Oct 27, 2016 01:30 |  #13
I have the Feisol 3442, which I love for normal AND travel, it's the only tripod I care to use. When I go international, it's small enough to fit my carry on, and I dont like flipping it backwards, so I just take off the ballhead and done.
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
NDAPhoto
Joined Jul 2015
Post edited over 6 years ago by NDAPhoto.
Nov 25, 2016 20:23 |  #14
Month old thread, but I'll mention the Mefoto Carbon Roadtrip fits inside a carry-on. Almost got the Globetrotter, a little bigger, but it was too close in size to the Gitzo basalt I was using. I've travelled with a Joby Gorillapod through full size Bogens and Manfrottos, so knew the compromise in size, weight and support I wanted. The carbon Roadtrip is compact at 15.25" folded and 62" fully extended. Only 2.4 lbs without head for comparison, but it does include a nice Arca-Swiss compatible ballhead. Does not creep with a 70-200 2.8 IS. Also got it from AliExpress for $249 delivered in 4 weeks. Genuine and $100 below the typical US price.
Dustman
Nov 26, 2016 13:07 as a reply to  @ NDAPhoto's post |  #15
Thanks for the input NDA, I appreciate it.
In the end I went with a Gitzo, not the original I planned, but a very similar model.
https://www.bhphotovid​eo.com …qd_series_1_tra​veler.html (external link)
It folds down to 14'' when closed, and is 3.1lbs with ballhead.
I believe it is the tiniest full tripod they make, but it is still solid as a rock. A lot more sturdy than I even imagined. First day out I shot with a 16 stop ND filter, and during a 9 minute exposure, was a huge gust of wind, which I was sure would cause me to do the very long exposure again. But to my surprise, the photo was sharp as a tack. So I am very very with my purchase so far.
10,276 views & 1 like for this thread, 13 members have posted to it and it is followed by 6 members.
1454 guests, 131 members online
