Thread started 26 Oct 2016 (Wednesday) 15:40
Yongnuo- Does YN-560tx work with YN-622c?
jpbimages
Oct 26, 2016 15:40 |  #1
I haven't found a solid answer from Google or Youtube:
Will HSS or ETTL work if I have a 560tx mounted on my camera and a yn-622c attached to a HSS or ETTL capable speedlight. I am trying to figure out what units I am going to buy as my Speed lights set-up.
Most of the time I will be shooting Manual so the 560tx with some 560 IV's will be perfect from what I have read and understood. But occasionally I would like to shoot outside and would like/need HSS and ETTL for more dynamic situations.
The reason I want the 560tx as my transmitter is the ability to shoot with 6 separate groups, whereas the 622tx only controls 3 groups.
Any suggestions?
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 7 years ago by MalVeauX.
Oct 26, 2016 16:03 |  #2
Heya,
Nope. I have both. The ETTL/HSS will not happen, you can trip them like manuals, but not like ETTL/HSS.
If you want ETTL/HSS, use the TX-622 & YN622. If you want manual, use 560/603.
Do you need 6 separate groups?
I use the 560III's with the TX-560. When I want ETTL/HSS I use my YN685 on camera. But I also have a YN622 so that I can use the YN685 off camera and keep ETTL/HSS (it has a built in YN622 & built in RF603). I can also use the YN685 the same as one of the 560III's because it has both wifi receivers and works on both protocols.
Very best,
1,313 views & 0 likes for this thread, 2 members have posted to it.
1264 guests, 174 members online
