FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 27 Oct 2016 (Thursday) 00:58
POLL: "Which would you use to run?"
CF main SD backup
6
54.5%
SD main CF backup
5
45.5%
11 voters, 11 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
CF as backup or SD as backup?
kaitanium
Post edited over 7 years ago by kaitanium. (2 edits in all)
Oct 27, 2016 00:58 |  #1
Got a 5d3. In this day in age of advancing memory card tech, it used to be SD cards werent as reliable as CFs. But now I think the game is level right? Speed aside, what would you guys choose to run in your cameras? CF as the main card and SD as backup or visa versa SD as main and CF as backup.
Currently Im thinking getting 1x 256gb SD card as a backup that always stays in the camera, and then running multiple 32gb cf cards as mains. In this scenario the SD card would get more writes in a shorter lifespan but is cheaper to replace
SD cards are generally cheaper. I dont care really about speed. The cards out these days are good enough for me in that department. Way better than what they used to be.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Oct 27, 2016 01:00 |  #2
What are you shooting?
Are you getting paid for it?
kaitanium
Oct 27, 2016 01:08 |  #3
Please explain the relevancy to the topic of those questions? Cost it seems like it's based on speed of card. Even the 50mb/sec SanDisk ultras would be good enough for me. So technically speaking I'd be fine with the cheapest model.
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket. (2 edits in all)
Oct 27, 2016 01:44 |  #4
To me, "back up" means back up. Speed has nothing to do with the question, and you even said, "speed aside".
Please explain what back up means to you.
John ­ from ­ PA
Joined May 2003
Post edited over 6 years ago by John from PA.
Oct 27, 2016 06:19 |  #5
Back to the OP's question, I would ask, what will be the method of transfer of images in the camera to computer. If one uses a direct cable to PC then the reliability situation is different than a method involving the removal of the card and using a card reader. CF card removal exercises the pins in the camera body. IMO the SD "connection" is less subject to issues caused by constant insertion and removal.
And I realize there will be plenty that chime in they have had SD cards fail, but I haven't.
kaitanium
Oct 27, 2016 08:44 |  #6
Left Handed Brisket wrote in post #18168175 (external link)
Still dont get the question. Backup is reliability. Correct, speed and price has nothing to do with the question...well sort of price as SD cards are cheaper.
John from PA wrote in post #18168260 (external link)
Back to the OP's question, I would ask, what will be the method of transfer of images in the camera to computer. If one uses a direct cable to PC then the reliability situation is different than a method involving the removal of the card and using a card reader. CF card removal exercises the pins in the camera body. IMO opinion the SD "connection" is more less subject to issues caused by constant insertion and removal.
cards out for transfer. Im not worried about pins. Never had an issue with pins in my tens of thousands of times i inserted or removed my cf cards. I suppose sd cards will be more reliable in that area.
Trvlr323
Oct 27, 2016 09:00 |  #7
kaitanium wrote in post #18168153 (external link)
You don't care about speed so I assume that you know the SD BUS on the 5D3 is significantly slower than the CF BUS. In other words, if you are writing the same size files to both cards it is going to take a lot longer for the buffer to flush to the SD card and consequently it will cause a bottleneck. In speed critical situations I always used CF only in the 5D3 for this reason. If you mean that you don't care about speed because both formats meet or exceed your requirements then it doesn't really matter which you use for backup. Your logic about SD cards seems sound but I don't think there is a big difference either way.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Wilt
Post edited over 7 years ago by Wilt. (3 edits in all)
Oct 27, 2016 09:13 |  #8
Got a 5d3. In this day in age of advancing memory card tech, it used to be SD cards werent as reliable as CFs. But now I think the game is level right? ... The cards out these days are good enough for me in that department. Way better than what they used to be.
  1. Internally, a CF card has always been a silicon chip encased in an outside package, with 24 microwires connecting contact 'pads' on the chip to the tiny female contacts of the CF.
  2. Internally, an SD card has always been a silicon chip encased in an outside package, with 9 microwires connecting contact 'pads' on the chip to the large male contacts of the SD.
Do you SEE anything in the above descriptions that makes a CF inherent more 'reliable' than an 'SD', judging by the description? I certainly do not.
From anecdotal evidence we have heard that CF cards endure cycles in the washing machine and come out operational after being allowed to dry.
CF enclosers are thicker than SD enclosures, but even SD does not bend very easily. Today I'll have to try driving over a CF and an SD on the pavement, to see if one ends up more damaged than the other.
CF has always had a 'speed advantage' over SD, as CF has 8 (parallel) connections while SD has One (serial) connection...for a single 'cycle' the CF moves 8 times as many bits of data as the SD. But that has nothing to do with 'reliability'
ardeekay
Gallery: 69 photos
Oct 27, 2016 09:53 |  #9
As a somewhat side note-I did have an issue with bent pins and a CF card . If I recall correctly, it was $370. Repair. But I still use CF primary in my 7Dll. FWIW
Rog
kaitanium
Post edited over 7 years ago by kaitanium. (4 edits in all)
Oct 27, 2016 09:54 |  #10
nqjudo wrote in post #18168394 (external link)
yup this is it. Im currently using sandisk 32gb CFs extremes at 60mb/s and its been wonderful over the 2 years ive had them. I do have faster ones at 120 that i use in conjunction but really do i notice a night and day difference in what i do (weddings)? Not really.
If reliability is the same, then for me, the SD card as mains may edge out better as it has 3 factors 1. non bendable pins (nice to have i guess, though I never experienced bent pins) 2. cheaper 3. built in sd card readers on my comps.
Thanks for the info all.
eelnoraa
Oct 28, 2016 12:44 |  #11
Wilt wrote in post #18168401 (external link)
Not so accurate on SD these days and back about at least 5 years. SD and uSD today use something called SIP package. There is no wire of any kind. It is a PCB embedded into some fiber/epoxy substrate. the plastic over of the SD is just for maintaining the form factor. That is how SD card are being advertised as water proof/dust/ice proof.
CF on the other hand, it is still expose PCB with SMT component, wire and connectors. So it is not subject to environmental effect. So in term of physical reliability, SD > CF. But both are very good to begin with, you shouldn't have any issues
In terms of product level reliability, no comparison here. CF >> SD. The reason is CF is a niche product these days. Volume is extreme small while profit is high. Manufacture didn't bother to go into cost reduction on CF product. CF these day still are on 19nm MLC or SLC. SD however, it is a volume product. Low cost is important. Most if not all SD today is in 16nm TLC. So from flash memory stand point, CF uses much higher quality flash inside.
Having the above said, for 5D3, CF as primary, SD as backup.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
Wilt
Oct 28, 2016 13:08 as a reply to  @ eelnoraa's post |  #12
Thx for bringing me up to date with the internal technology of CF vs. SD packing, and fundamental quality level of limited quantity vs. volume economy products.
kaitanium
Post edited over 7 years ago by kaitanium. (3 edits in all)
Oct 28, 2016 13:58 |  #13
good stuff thats probably the answer i was shooting for! thanks for the info! This means I still rather have a more reliable CF as backup. Except hi-cap CFs are pricey!
kaitanium
Oct 28, 2016 15:06 |  #14
and if someone is curious about speeds using a SD, looks like its decent (at least for me): http://blog.photoshelt​er.com …or-the-canon-5d-mark-iii/ (external link)
again for me, im not too worried.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 7 years ago by CyberDyneSystems.
Oct 28, 2016 16:09 |  #15
Compact flash as main card.
SD as "back up"
These days I end to shoot RAW to CF and jpeg to SD, but on occasion I write RAW to both as the in camera "RAID 1 Mirror" in case a car dfails.
I posted just recently on my own experience of CF reliability vs. SD,. I found that SD had something like a 30X higher failure rate than CF (again, only one mans' data)
CDS' HOT LINKS
6,502 views & 1 like for this thread, 12 members have posted to it and it is followed by 4 members.
1507 guests, 135 members online
