Thread started 28 Oct 2016 (Friday) 08:15
Intel i5 vs. i7 for photo editing
dan.k78
Post edited over 7 years ago by dan.k78.
Oct 28, 2016 08:15 |  #1
I can make an educated assumption that spec for spec that the i7 is a faster processor and that if money were no object to simply go for the i7 and call it a day. Since money is an object, my question for those with experience, is whether the i7 is worth the extra money for straight up photo editing (I don't game, or do video). The rest of the specs (for a laptop) would be in the realm of a SSD and 16GM RAM.
Thoughts? Suggestions?
Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Oct 28, 2016 08:29 |  #2
Single core performance has the largest impact in Photoshop and Lightroom, so an i5 and i7 from the same generation with the same clock speed will perform pretty much the same. There are some actions, such as exporting, that will make good use of multi cores, but performance gain drops off significantly after 4 cores in Lightroom and 6 cores in Photoshop.
Take a read through Puget Systems Lightroom CC/6 Multi Core Performance article. https://www.pugetsyste​ms.com …lti-Core-Performance-649/ (external link)
They also have a similar Photoshop article. https://www.pugetsyste​ms.com …lti-Core-Performance-625/ (external link)
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
sfreer
Joined Apr 2013
Oct 28, 2016 08:47 |  #3
Mobile i5 are 2 core and the i7 are 4 core. Hard to beat pure clock speed and the quad core can be felt at times. Get the fastest i7 you can afford. There is usually a sweet spot in MHz/$ in the laptop build configuration.
FuturamaJSP
Oct 28, 2016 09:03 |  #4
https://www.cpubenchma​rk.net/singleThread.ht​ml (external link)
note that the i5 4690K can be overclocked to match the performance of the more expensive i7 and xeon cpus
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
sfreer
Joined Apr 2013
Oct 28, 2016 09:10 as a reply to  @ FuturamaJSP's post |  #5
OP is looking at a laptop so no overclocking.
FuturamaJSP
Oct 28, 2016 09:14 |  #6
there are several laptop cpus on that list
blah blah blah
DA (external link)
dan.k78
Oct 28, 2016 09:52 |  #7
Thanks for the great info! Looks like I have some reading to do.
John ­ from ­ PA
Joined May 2003
Post edited over 7 years ago by John from PA. (2 edits in all)
Oct 29, 2016 12:30 |  #8
Dell has some deals available through their outlet center. Go to http://outlet.us.dell.​com …IR&cid=258996&l​id=4635114 (external link) and see if anything is of interest. Use the filter panel along the left to filter down the choices to (for example) an i7, SSD, new or refurb, etc. But should you purchase, click on "Coupons" near the top right because often you can get further discounts.
10,122 views & 0 likes for this thread, 5 members have posted to it.
1062 guests, 104 members online
