Thread started 03 Nov 2016 (Thursday) 10:47
Stabilizing a Reflector
RandMan
Joined Mar 2012
Post edited over 7 years ago by RandMan.
Nov 03, 2016 10:47 |  #1
Hi All,
I want to go out to a craft store today and pick up one of those white foam boards that people often use for a nice little makeshift reflector. My question is: without an assistant holding it up for you, what's the best way to keep it standing up where you want it?
This weekend I am going to be photographing some various food dishes on a table. I'd like to use my umbrella speedlite setup as the main light and use the foam as a reflector.
EDIT: I'm not looking to have the reflector mounted on a light stand or anything, just sitting on the table near the food.
Thanks,
Randy
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
OceanRipple*
Joined Dec 2014
Nov 03, 2016 11:00 |  #2
RandMan wrote in post #18174689 (external link)
Hi All,
Thanks,
Randy
Hi, One of these;
https://www.bhphotovid​eo.com …_275_Mini_Clip_​Clamp.html (external link)
on one of these:
https://www.bhphotovid​eo.com …250_Long_Double​_Stud.html (external link)
itself held in the outboard Grip of - one of these:
https://www.bhphotovid​eo.com …_master_40_c_st​and_w.html (external link)
or, of course, anything with equivalent functionality ..
a cheaper setup could be based around one of these:
https://www.amazon.com …fRID=DSJ7708PVA​VH3RYY7SZT (external link)
RandMan
Joined Mar 2012
Nov 03, 2016 13:02 |  #3
OceanRipple* wrote in post #18174703 (external link)
Hi, One of these;
on one of these:
Thanks for the reply - I just went back and edited my original post because I left out a significant detail: I just want the reflector kind of sitting on the table rather than mounting it on a stand.
OceanRipple*
Joined Dec 2014
Nov 03, 2016 13:06 as a reply to  @ RandMan's post |  #4
Oops!:-)
Foodguy
Joined Mar 2012
Post edited over 7 years ago by Foodguy.
Nov 03, 2016 13:19 |  #5
Foam core- Score it with a sharp knife which will allow it to bend along the score line and you can simply set it on the table anyway you like. Alternatively, I often use a roll of paper towels as a support to lean smaller pieces on.
My answer for most photography questions: "it depends...'
dmward
Gallery: 29 photos
Nov 04, 2016 21:51 |  #6
Another option are the "frogs" that go in the bottom of floor arrangement.
Also available at Michaels. They are a lead weight with lots of sharp pointy spines sticking up.
They come in different sizes.
HERE (external link)
bpalermini
Gallery: 203 photos
Joined Mar 2011
Nov 04, 2016 22:21 |  #7
I use A clamps (spring clamps) (external link) to make legs for foam core. Cheap and works great.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket.
Nov 05, 2016 06:15 |  #8
These are perfect for table top photography.
http://www.michaels.co​m …Cpdv%7Cm%7Cprd%​7C10133201 (external link)
You can use the "inside"(all three panels) to wrap a lot of light around the subject, or you can turn the board around and use just the center panel for more directional fill. I use both black and white ones, and have even shot a speedlight through the white ones once or twice.
RicoTudor
Joined Jul 2014
Post edited over 7 years ago by RicoTudor.
Nov 05, 2016 13:44 |  #9
I like Bob's suggestion for clever improvisation. That said, real grip gear takes care of foam core positioning in all possible cases and dimensions. I consider foam core and grip gear to be essential for studio photography, and elements that will deployed continuously. Lifetime investments.
Canon, Nikon, Contax, Leica, Sony, Profoto.
PalaDolphin
Joined Sep 2016
Nov 06, 2016 14:33 |  #10
Foam core. It's probably pennies. And here I am spending bucko bucks on reflectors and holders.
F2Bthere
Joined Oct 2015
Nov 06, 2016 23:44 |  #11
A second piece of foam core taped to the first to form a V (like a mini V Flat). You can stand it where you want it and even use it as an open V to reflect light off both boards if that is appropriate for your image. Use white tape and it can double as a backdrop if slightly out of focus. Get the kind that's white on one side and black on the other, use black tape on the black side and you have a great black backdrop plus negative (light absorbing) reflector.
C&C always welcomed...
On my images, of course, and on my words as well--as long as it's constructive :).
https://www.instagram.​com/storyinpictures_co​m/ (external link)
DigitalDon
Joined Aug 2012
Nov 07, 2016 18:27 |  #12
DIY foam board holders https://m.youtube.com/​watch?v=FJlvwCQh1F4 (external link)
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
3,903 views & 9 likes for this thread, 10 members have posted to it and it is followed by 6 members.
1061 guests, 102 members online
