Thread started 10 Nov 2016 (Thursday) 17:10
canon extender x1.4 not showing up in properties Help please !
keeperseeker
Gallery: 179 photos
Joined Dec 2011
Nov 10, 2016 17:10 |  #1
Just got a used x1.4 extender ver. iii. seems to work good,,except its does not show up on focal length info. My x2 extender ver iii ,,, only shows up some times on the focal length info. Anyone got any ideals as to cause of this,,,or solutions ? I find this a rather strange situation !
Never make a decision when you have to pee. L Cohen
Tapeman
Sliced Bread
Joined Jan 2004
Nov 10, 2016 17:22 |  #2
A little more information would be helpful. Camera? Lens? Maybe even some of your settings?
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
keeperseeker
Gallery: 179 photos
Joined Dec 2011
Nov 10, 2016 17:33 as a reply to  @ Tapeman's post |  #3
7dmk ii with 100-400 4.5/5.6 is usm ii. different setting,,,but info of focal length is not getting listed . put extenders on lens first,,then mounted to camera. Camera off when switch made.
don1163
Gallery: 27 photos
Joined May 2015
Nov 10, 2016 17:37 |  #4
Do the extenders show up when used on other lenses?
1DX, 500L f4, 70-200L f2.8II, 100L f2.8 macro ,16-35 f4, 1.4xIII, Metz 64-AF1
keeperseeker
Gallery: 179 photos
Joined Dec 2011
Nov 10, 2016 17:49 as a reply to  @ don1163's post |  #5
I only have the 100-400 that works with extenders. ok just tried with them on my on my Rebel T3i the 2x shows ok but the x1.4 is not showing. the 2x on my 7dmkii is showing up.
don1163
Gallery: 27 photos
Joined May 2015
Nov 10, 2016 18:15 |  #6
Not sure what your problem could be...everytime I have used extenders they have always shown up in the focal length information no matter which lens I have used..
Maybe get a friend to try the extenders on their camera to see if they show up..
Bassat
"I am still in my underwear."
Joined Oct 2015
Nov 10, 2016 18:21 |  #7
Not sure any of this is relevant, but data is data.
Camera: 6D
TC: EF 1.4X II
Lenses: 135L, 200 2.8L II, 70-200 f/4L IS, 100-400Lc.
I tried mounting TC to lens, then mounting TC/Lens to turned off camera.
I also tried leaving TC on camera, leaving camera turned on, and just changing lens.
The TC showed up in my EXIF every time.
The only time my TC does NOT show up is when I use them on the 100mm f/2.8 macro. I think the intervening ET causes that.
keeperseeker
Gallery: 179 photos
Joined Dec 2011
Nov 10, 2016 19:07 |  #8
Thanks for your suggestions Tapeman & Don. Update,,,,,I just found scotch tape on 4 of the terminals of the x1.4 extender ! Removed it,,thinking that would of been the problem ! So on my 7dmkii...100-400 set at 400,,am getting a focal length of 560mm with my x1.4 on. shouldn't be 500mm?
Archibald
You must be quackers!
Gallery: 789 photos
Nov 10, 2016 19:12 |  #9
keeperseeker wrote in post #18181243 (external link)
I was just going to suggest looking for scotch tape on four of the terminals...
The next part is a mathematical exercise.
Bassat
Joined Oct 2015
Nov 10, 2016 19:26 |  #10
400 x 1.4 = ?
keeperseeker
Gallery: 179 photos
Joined Dec 2011
Nov 10, 2016 19:36 |  #11
Thanks every one,,,this "crisis " ,,,seems to have been successfully resolved ! I,ve heard of putting tape over terminals,,,Just can't remember propose of this,,,lol happy all looks good now . Thanks again.
Tapeman
Sliced Bread
Joined Jan 2004
Nov 10, 2016 20:51 |  #12
Glad it turned out to be an easy fix.
amfoto1
Nov 10, 2016 22:47 |  #13
7DII is "f8 capable" so it can AF the 100-400mm with a 1.4X attached, so no "tape" is needed. You'll be restricted to the center AF point only, when using an f8 lens/TC combo.
However, a 2X on the 100-400makes for an f11 combo that should cause the AF to turn off, unless you tape it up. Tape on a couple of the contacts will "fool" the camera into not knowing the teleconverter is there and so will not record the change in focal length in the EXIF. (Google for info about which contacts to tape up... I don't know since I'd never put my 2X on my 100-400.)
Tc202
Gallery: 436 photos
Best ofs: 8
Joined Mar 2012
Nov 11, 2016 11:02 |  #14
When I use converters sometimes this occurs if you attach the converter to the camera body first. If I attach it to the lens first the problem is resolved. Also, somewhere I read about Canon recommending you to always attatch the converter to the lens first.
Thomas
3,235 views & 5 likes for this thread, 7 members have posted to it and it is followed by 2 members.
927 guests, 117 members online
