Thread started 14 Nov 2016 (Monday) 07:32
GTX 680 vs GTX1060 for Lightroom and Photoshop
the.forumer
Joined Oct 2011
Nov 14, 2016 07:32 |  #1
I do a lot of photo and video editing, and from the Premiere Pro CC guys, I heard the CUDA count and bandwidth is v important.
I know 680 is a lot older than the current 1060, but it was the king of the hill last time, and it's a lot cheaper 2nd hand now.
Is it still worth getting over 1060?
Bleufire
Nov 14, 2016 08:44 |  #2
the.forumer wrote in post #18183947 (external link)
I think depending on the price but a 1060 would stomp the 680. What is the price differences between them? A 1060 3GB can go for under $200 if I seen correctly (here is an old link for one at $143 (external link)) and at that price it wouldn't make sense to go for a 680.
Also, for photo editing, it is largely considered that a GPU won't improve editing but for video that is a topic for another video specific forum.
5D*Sigma 50/1.4*EF 17-40/4
New to Photography? ----> ENJOY! Canon DSLR! (external link)
the.forumer
Joined Oct 2011
Nov 16, 2016 08:56 |  #3
Bleufire wrote in post #18183999 (external link)
the 680 is $100 cheaper than a new 1060.
I am running in 4k resolution. So upgrading the GPU does not do anything for Lightroom?
How about upping the ram from 16gb to 32gb? i just want to speed up the image to image loading in Develop modules. (yes I have 1:1 previews and smart previews loaded and enabled).
Bleufire
Nov 16, 2016 09:48 as a reply to  @ the.forumer's post |  #4
Here is an interesting video...
https://www.youtube.co​m/watch?v=EeBqmM2mOjQ (external link)
Plus, a 680 isn't a recomended card for LR:
https://helpx.adobe.co​m …kb/lightroom-gpu-faq.html (external link)
For NVIDIA cards, consider using a card from the GeForce GTX 760+ line (760, 770, 780, ...) or from the GeForce GTX 900 series
A 1050 or 1050Ti would be the best bet for the price and will be equal in power or greater than a 680 while sipping less electricity and generating much less heat:
https://www.youtube.co​m/watch?v=BUOrnp2PjK4 (external link)
Regarding the RAM and Lightroom, that really is up to your usage. Leave a system monitor or resource monitor tool with a graph and do some editing as normal and see if your usage even makes use of the 16GB that you have. If you hit up crazy x25 shots of 24MP panoramas, yeah, that 32GB increase could come in handy. But I can't really speak for you because I don't know your PC usage, DSLR model and RAW output sizes, different editing task and/or other background applications you like to leave running.
The best thing to do would be RAM>CPU>Fast Storage (HDD/SSD) and then way off in the very very last bit to spend money for performance increase would be a GPU. Excess RAM does nothing for speed but not enough RAM is everything involving speed. If you understand what paging file is then you'd understand why not enough RAM is the devil for LR.
RDKirk
Adorama says I'm "packed."
Joined May 2004
Nov 16, 2016 10:47 |  #5
Two things for video editing:
Onboard ram. Premiere Pro and Davinci--two I know--really need more than 2 gigs of onboard ram. Four is minimum. The big problem of too little onboard ram is when you start doing real-time activity, like scrubbing through a sequence with audio and a few effects in place (and yes, ordinary sharpening or color correction is an "effect"). The editor tries to cache into the card's onboard memory, runs out of room, and you suffer a hard gpu crash. Sometimes it crashes so hard the gpu is stuck and you have to restart the computer. This of course is most likely to happen when you've done all your editing--it never happens when you first upload the clip.
Memory bandwidth. Number of CUDA cores is what manufacturers love to brag about, but they all have "enough" these days. It's memory interface width that brings the big bang. The minimum for decent operation is 128 bits. No point spending more money on a card unless you're making the jump to 256 bits.
So, basically, at least 4 gigs of onboard ram and a 128 bit memory interface width. Any current card with those specs will have all the necessary CUDA cores and bandwidth along for the ride.
tim
Light Bringer
Nov 17, 2016 12:08 |  #6
Generally Photoshop and Lightroom get little benefit from faster graphics cards. I suspect the cheapest nVidia card in the latest range would do much the same as the most expensive.
the.forumer
Joined Oct 2011
Nov 18, 2016 19:42 |  #7
i see.
How about a CPU jump from a heavily overclocked 2500k (4.7Ghz) to a 6700K (OC to 4.5Ghz)? How much of a difference will it make specifically in Lightroom?
It's quite frustrating to see that the features in Lightroom are among the best, but when using CaptureOne Pro, I can instantaneously review all my images without lag and without the need for higher end hardware. :(
gabebalazs
Bird Whisperer
Gallery: 52 photos
Post edited over 6 years ago by gabebalazs. (2 edits in all)
Nov 18, 2016 23:36 |  #8
I use Photoshop CC and work in Adobe Camera Raw a lot. I upgraded my computer a couple months ago:
- My previous system: i7-4771 (3.5Ghz), 16gb DDR3 RAM, GTX750Ti, older HDD
- My new system: i7-6700K, MSI Gaming Carbon motherboard, 32GB DDR4 Ram, GTX 1060 (6GB), Samsung Evo 850 SSD
I did not experience a big jump in performance. More RAM definitely helps when I edit more files in ACR. SSD helps loading and saving stuff, but still no dramatic difference (at least not in Photoshop/ACR). Also, editing steps such as geometric corrections, local adjustments, etc. did not become much faster in ACR.
I don't think Photoshop/ACR can properly utilize a powerful system so we're basically facing diminished returns above a certain level of equipment.
The general consensus is that more RAM and a higher clockspeed processor (as opposed to 6 or 8 cores but at a slower speed) helps most in Photoshop/Lightroom. Most tasks cannot utilize more than 4 cores.
Funny that my current system would be great for gaming but I never ever do any games. :rolleyes:
p.s. One thing I did notice was that when I switched from a 1080p monitor to a 1440p one, it considerably slowed down Photoshop/ACR (using the same computer). I believe doing it in 4k slows it down even more.
SONY A7RIII | SONY A7III | SONY RX10 IV | SONY RX100 | 24-70 2.8 GM | 70-200 2.8 GM | 16-35 F/4 | PZ 18-105 F/4 | FE 85 1.8 | FE 28-70 | SIGMA 35 1.4 ART | SIGMA 150-600 C | ROKINON 14 2.8
Gabe Balazs Photo (external link)
Nature Shots Portfolio (external link)
Perfectly ­ Frank
I'm too sexy for my lens
Gallery: 147 photos
Nov 19, 2016 12:01 |  #9
gabebalazs wrote in post #18188636 (external link)
This is helpful, thanks for sharing.
When you see my camera gear you'll think I'm a pro.
When you see my photos you'll know that I'm not.
My best aviation photos (external link)
My flickr albums (external link)
the.forumer
Joined Oct 2011
Nov 22, 2016 08:43 as a reply to  @ gabebalazs's post |  #10
yes! that is exactly what I'm facing now.
I switched from 1080p >> 1440p >> and now to 4K, and the slowdown is terrible. my new gpu (gtx1060) didn't help at all, and i had to disable it for faster performance actually.
Bleufire
Nov 22, 2016 08:46 as a reply to  @ the.forumer's post |  #11
That's interesting.
What did you have in there before?
gabebalazs
Bird Whisperer
Gallery: 52 photos
Nov 23, 2016 07:22 as a reply to  @ the.forumer's post |  #12
Yeah, that's one drawback of a larger monitor, and according to Adobe that's where a nicer graphics card is supposed to help. Apparently, it doesn't as much. Actually, I think Adobe says that certain functions are improved with a GPU while others aren't affected.
I noticed there is a large difference with the adjustment sliders, for example it makes a big difference when I make geometrical adjustments (e.g. tilt). Without the GPU it is very choppy and it's hard to quickly adjust but with the GPU enabled it is fluid, even though the image is slightly blurred while adjusting the slider. But that's a minor trade-off.
What I also started doing recently is resizing my ACR window to a smaller size (as opposed to using it full screen) when I want faster multiple-file editing (and don't need to look at every image full screen). The size of the ACR (or Lightroom?) window actually affects processing speed. So even though I'm using a larger monitor than I did before, I can speed up processing by making the ACR window smaller. I think it just comes down to how many pixels the GPU (or the CPU) needs to process.
10,572 views & 2 likes for this thread, 6 members have posted to it and it is followed by 5 members.
1501 guests, 134 members online
