Thread started 14 Nov 2016 (Monday) 08:57
New 100-400V2 questions
Bsmooth
Nov 14, 2016 08:57 |  #1
I had the old one and now have the new one and use it for BIF mostly. When the subject is in focus the images are great. But I'm finding even on birds on branches and Ducks in the water I'm getting very inconsistant results with my 1DMkIV.
I was out yesterday and was shooting the usual chicka dees and mallards and the shots look great at initial glance, but when viewed at around 66% in Photoshop they just don't look as clear.
Initially when I got the lens a few months ago the results seemed much better. But I've made a few changes in how I shoot since then. I'm now using Back button AF, which means all the time Servo AI and I switched to Manual exposure.
The manual exposure shouldn't make a difference to AF but I'm seriously wondering whats going on.
The shots are never grossly out of focus, but just enough to really not make them keepers.
Anyone have any idea what it might be ? Its probably just me, but at this point I'm seriously thinking of opting out of the back button focusing and starting from scratch again.
Bruce
gjl711
Nov 14, 2016 09:29 |  #2
Could be so many things from technique to incorrect MFA. MFA is easy to test so I would start there and eliminate any mechanical cause. Then it's time to look at how you are shooting. Could be that AI Servo is missing or something else.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Nick5
Nov 14, 2016 09:48 |  #3
Bsmooth wrote in post #18184012 (external link)
Just checking to make sure you did remove the Focus from your shutter.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
Archibald
You must be quackers!
Gallery: 789 photos
Post edited over 7 years ago by Archibald.
Nov 14, 2016 10:27 |  #4
Do some test shots of ideal subjects so you know the subject is not contributing to the problem. An ideal subject is flat, high contrast, way bigger than the AF point, well lit, and perpendicular to the lens axis. Make sure there is nothing in the test scene that could tempt the AF system to grab instead of the intended subject.
Take several shots of the ideal subject with the lens wide open at a high shutter speed. Have a look at the results to see if the subject is tack sharp, and if not, if it is always back- or front- focusing by the same amount.
If the shots are sharp, then things are working properly. There might be a problem with more difficult subjects which might not be the system's fault, or maybe it's your technique. If it is consistent but always a bit behind or in front, then your system needs MFA. If it is inconsistent, sometimes in front and sometimes behind, then the lens or camera might have an AF problem that needs servicing by Canon.
amfoto1
Nov 15, 2016 21:47 |  #5
What focusing pattern are you using? Single point, expansion points, all points? (
I'm not sure which AF patterns 1DIV offers. I use 100-400 II with my 7DIIs, also with BBF and AI Servo much of the time, and find I get the most consistency when I use single point. Of course, that's more work keeping the point right on the subject. Sometimes I'll use expansion or small zone patterns, but mostly only when there's plain background and/or nothing too close behind or in front of the subject that might distract AF and cause it to lose tracking. I do see a bit less consistency, regardless, but use those patterns anyway when subjects are especially fast or moving erratically.
Some other ideas or possibilities...
Manual exposure should help AF speed, if anything. The camera not needing to meter and set exposure will usually make it faster.
Do you have a filter on the lens? I've seen filters cause issues. Do you use the lens hood regularly? I've seen those help AF performance at times.
My cameras (again, 7DII, not 1DIV) have menu settings that can be used to delay how quickly the camera jumps AF to another object, if I momentarily fail to keep the AF point right on target. It seems counter-intuitive, but I often set that to slightly "slower". It doesn't slow down AF or tracking, only effects how quickly the AF will move to a different target. It can be problematic if subjects are changing direction a lot, so other times I'll zero it out or even set it slightly faster.
Another setting I use prioritizes focus accuracy versus shutter release. Basically, it tells the camera whether I want the shutter to fire immediately or, if necessary, delay release until AF is achieved. There are two of these settings on my camera... one for "1st image" and the other for "2nd (and any subsequent) images in a continuous burst". If I recall correctly, this only functions in AI Servo.
Not sure if the 100-400mm is a "varifocal" or a "parfocal" zoom. I suspect it's partially varifocal (like most modern AF zooms). That being the case, AI Servo should immediately correct for changes in focal length while tracking a subject. But you might try locking the zoom in place sometime, see if you get better consistency that way (and it's nice the 100-400 II has that neat ring to quickly and easily lock or unlock the zoom).
Finally, I don't think you 1DIV even has AI Focus mode... but my 7DII do... and I avoid it like the proverbial plague!
You mention having "changed" some things... Anything else you didn't mention? Sometimes it's an unexpected item.
It might just be a matter of getting accustomed to the lens and it's focusing speed. While it's no slouch, I don't think it's quite as snappy focusing as f2.8 and faster primes and zooms, perhaps even a tiny bit slower than f4 primes & zooms I use. After all, it's an f5.6 lens at 400mm, f5 up to about 300mm if memory serves.
Oh, and one more thing I often do... whenever light allows, I stop the lens down a little. That just makes for slightly greater depth of field that might offset any slight amount of missed focus.
And, the other suggestions to run an MFA test on the lens are good ones.
Hope this helps! Let us know.
2,043 views & 0 likes for this thread, 5 members have posted to it and it is followed by 4 members.
1618 guests, 138 members online
