Thread started 16 Nov 2016 (Wednesday) 12:12
Share your ultra wide angle photos
Jaskyzie
Joined Nov 2016
Nov 16, 2016 12:12 |  #1
I recently bought 16-35 mm f/4 lens and used it a couple of time. I found I used most at 35 mm end (sometimes at 24 mm) , never used once at 16 mm end. I found that I either don't like or am not used to see the distortion at 16 mm. I wonder if people can share their photos using ultra wide angles. Thanks!!
Trvlr323
Nov 16, 2016 12:20 |  #2
https://photography-on-the.net …/showthread.php​?t=1384030
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Jaskyzie
Joined Nov 2016
Nov 16, 2016 12:59 as a reply to  @ Trvlr323's post |  #3
Thanks for the link. A lot of really nice photos!
windpig
Chopped liver
Post edited over 6 years ago by windpig.
Nov 16, 2016 14:00 |  #4
UWA is an acquired taste. It truly challenges. I use to be a 100-300 kind of shooter because it was easier to compose. For sure I take less images with UWA, but most of the keepers stand out. My current walk around is a Fuji X-T1 with a 10-24 on it (15-36 FF equiv FOV).
Go ahead, spin the wheel.
Jaskyzie
Joined Nov 2016
Nov 16, 2016 15:55 as a reply to  @ windpig's post |  #5
It must be. I have seen a lot beautiful sunset or ocean view pictures taken with UWA lens and I really like the sweeping views. But using it myself is a different story. Maybe I should spend more time playing with it. How do you like the UWA lens as walk around lens? When I traveled with it, I often found the need to switch to a telephoto lens and it was inconvenient.
windpig
Chopped liver
Nov 16, 2016 16:10 |  #6
the 10-24 is the walk around lens, TS-E17 is my other UWA, not a walkaround for me:-)
Jaskyzie
Joined Nov 2016
Nov 17, 2016 18:08 as a reply to  @ windpig's post |  #7
You must really like UWA!:-)
windpig
Chopped liver
Nov 17, 2016 19:50 |  #8
:-P
TS-E17 and TS-E24II are amazing. The shift makes for the best architectural photography.
1,942 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
1444 guests, 187 members online
