Thread started 17 Nov 2016 (Thursday) 15:31
Center Focus Point/Recompose or Outer Focus Points?
Cranberry ­ Dad
Joined Apr 2014
Nov 17, 2016 15:31 |  #1
I've been doing more portrait shooting lately, and I'm still trying to determine if it is better to use the center focus point and recompose (which has always been my traditional way of shooting), or to use the outer focus points and hold focus directly on the eye instead of recomposing. It seems that the outer focus point method would be better, particularly when shooting at wider apertures, but I'm not sure if it makes that much difference. Thoughts/advice?
Trvlr323
Nov 17, 2016 15:38 |  #2
I typically use the centre point and recompose but I've used the outer points as well. I don't think there is a wrong choice as long as you're getting good results. The centre point may be more sensitive than the outer points so it might make sense to use the centre point in difficult conditions, especially if you are having trouble focusing with the outer ones. Hope that helps.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Archibald
You must be quackers!
Gallery: 789 photos
Nov 17, 2016 15:51 |  #3
When shooting critters with my 100-400mm, it is important to be quick. That means I almost always use the center point and recompose if I can. Often there is not even an opportunity to recompose.
But for more static situations, especially with wider lenses used with a large aperture, it is best to use the off-center AF point.
silvermesa1
Joined Aug 2013
Nov 17, 2016 16:32 |  #4
when using the center point focusing method, do you focus on the subjects eyes then recompose the subject in the frame?
Cranberry ­ Dad
Joined Apr 2014
Nov 17, 2016 17:12 as a reply to  @ silvermesa1's post |  #5
Thanks for the replies. Yes, I typically focus on the subject's eye and then recompose.
fplstudio
Joined Jun 2015
Nov 25, 2016 04:53 |  #6
It depends. My experience suggests that focus and recompose with fast lenses will most likely be a failure. With f/4 and above it is generally ok.
10+ years with Canon, now new fresh air with Sony Full Frame
A7R3 | A6300 | MC-11 | FE 16-35 GM | EF 35 1.4 Art | FE 55 1.8 | FE 85 1.8 | EF 70-200 4L IS | FE 100-400 4.5-5.6 GM OSS | E 10-18 4 OSS | E 35 1.8 OSS
Godox AD200 | V860ii | 2x TT600
hqqns
When the frick did I get this new title and why?
Gallery: 29 photos
Post edited over 6 years ago by hqqns.
Nov 25, 2016 05:04 |  #7
The problem with recomposing is that what you had focused on will be in a different focal plane and unless the DOF is great enough then your subjects eyes in your example will thrown out of focus.
subby
Proud owner of a late ADHD diagnosis.... at age 47, whoop. Meds are a game changer: first time in my life I love my work...crazy
"I am 48"
windpig
Chopped liver
Nov 25, 2016 11:24 |  #8
Shorter focal lengths do not lend themselves to focus/recompose. To much focal plane angle change.
Go ahead, spin the wheel.
4,171 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1164 guests, 149 members online
