I have an 1100w/s Elinchrom Ranger RX Speed AS.
Honestly, I can't figure out why, or when someone would ever really need an 1000w/s+ light. Could someone... heh heh... shed some instances when one would be appropriate?
Nov 17, 2016 21:05 | #1 I have an 1100w/s Elinchrom Ranger RX Speed AS. Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
MatthewPatrick Senior Member 395 posts Likes: 12 Joined Jul 2008 Location: New England More info Post edited over 7 years ago by Matthew Patrick. | Nov 17, 2016 21:14 | #2 It would be handy for many uses, such as overpowering the sun, shooting with large format at f/64 or shooting groups with large modifiers where lots of DOF is required.
Wouldn't a 500W/S light (e.g. Profoto B1) be very well capable of overpowering the sun? Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
MatthewPatrick Senior Member 395 posts Likes: 12 Joined Jul 2008 Location: New England More info | A B1 can overpower the sun under certain conditions, it depends on the sync speed and weather. It's true that many people wouldn't need that much power but sometimes it's nice to have the flexibility, especially if it's work for a paying client.
RicoTudor Senior Member 677 posts Likes: 386 Joined Jul 2014 Location: Chicago, IL More info | Nov 17, 2016 22:01 | #5 I need 1000Ws to provide ambient fill for my studio of 240 sq.ft. using bare bulb. Key requires only a bit more, like 18Ws. Aperture in this case is f/5.6, or so. Wide view of a model shoot: Canon, Nikon, Contax, Leica, Sony, Profoto.
ImageMaker... looks like I picked a bad week to give up halucinagens More info Post edited over 7 years ago by ImageMaker.... (3 edits in all) | Nov 17, 2016 22:23 | #6 I use my Eli Ranger RX AS Speed outdoors HS and get 1/8000 1.4-2.8. Full power is very useful. Love it. If you have a large modifier, that can eat up a few w/s too. Faster Recycle time at lower power settings is also a benefit. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
The weight of the pack though. I've had it shortly, but I've been considering ditching it and going with the B1. Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
Nov 17, 2016 23:04 | #8 And you will have opportunity to use bigger modifiers for softer light (if needed). You dont always need it or use it, but if you do, lower ws strobe can not do that
Nov 18, 2016 01:00 | #9 Permanent banBetter to have power you don't need than to need power you don't have. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
ImageMaker... looks like I picked a bad week to give up halucinagens More info | Nov 18, 2016 06:03 | #10 quadwing wrote in post #18187637 The weight of the pack though. I've had it shortly, but I've been considering ditching it and going with the B1. You can drop the weight by 5 pounds and add 50% more flashes. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
LeftHandedBrisket Combating camera shame since 1977... More info | Nov 18, 2016 06:11 | #11 Don't remember the size packs we used to use, but we would cut all ambient, open the shutter and pop the flashes three times ... 4x5 transparencies. Only way to get the DOF we needed to shoot a corner of a room filled with furniture. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
jcolman Goldmember More info Post edited over 6 years ago by jcolman. (2 edits in all) | Nov 18, 2016 07:54 | #12 quadwing wrote in post #18187592 Wouldn't a 500W/S light (e.g. Profoto B1) be very well capable of overpowering the sun? I guess the most I'll be using the light for is at most group portraiture on sunny days with a 69" Elinchrom modifier, f/16 as probably the maximum aperture I'd use. Depends on how close the light is to your subject and how bright the ambient light is. If you were trying to light a large group of people with the light in a modifier, set back about 30 feet, then the answer might be "no". I used two 1500 w lights when lighting a large group (about 75 people) a few years ago.
Foodguy Goldmember 1,324 posts Likes: 217 Joined Mar 2012 Location: Having too much fun in the studio More info | Nov 18, 2016 09:23 | #13 It all depends on what you're doing. I shoot with a view camera at very low ISO's, and seldom use any ambient light. Sometimes when lighting large sets, it just takes a lot of light to do it. Image hosted by forum (825230) © Foodguy [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. My answer for most photography questions: "it depends...'
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info Post edited over 6 years ago by bobbyz. (3 edits in all) | Nov 18, 2016 19:11 | #14 My Einstein can't over power sun when I need it. This is with double diffused softbox and I Einstein is 640ws. I tried with Kacey dish and just matches sun in the afternoon. Better to have more power but lot better to have strobes which go much lower in power and also let you do HSS. Some day cameras will let you shoot past the slow max sync speeds of 1/200, then it won't matter much. Fuji XT-1, 18-55mm
I don't ever ever ever use HSS. I always just use ND filters; that's why I was considering the B1; I can use the ND filters to kill the sun, and then use the B1 to light. I don't know, I just hike a lot with my lights and would prefer not to carry a 15 pound battery pack; even with the battery light, it's still heavy. >.< Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
| Latest registered member is semonsters 1452 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
