Thread started 20 Nov 2016 (Sunday) 12:05
Short Bokeh test 100mm macro 50L, 85L, 135L minimum focusing distance
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 20, 2016 12:05 |  #1
I just wanted to see how good the bokeh was at macro distances with the 100mm macro, and then just decided to shoot the other ones at their MFD.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825538.jpg
Image hosted by forum (825538) © Moncho [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825539.jpg
Image hosted by forum (825539) © Moncho [SHARE LINK]
Carpe Diem
(Seize the carp!)
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 20, 2016 12:06 |  #2
85L vs 135L
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825541.jpg
Image hosted by forum (825541) © Moncho [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825542.jpg
Image hosted by forum (825542) © Moncho [SHARE LINK]
Carpe Diem
(Seize the carp!)
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 20, 2016 12:08 |  #3
50L and an overview of the setup, I hope this is useful.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825543.jpg
Image hosted by forum (825543) © Moncho [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825544.jpg
Image hosted by forum (825544) © Moncho [SHARE LINK]
Carpe Diem
(Seize the carp!)
MatthewK
Gallery: 1093 photos
Nov 20, 2016 12:39 |  #4
I like these sort of comparisons, thank you for taking these!
The MFD on the 85L is one of the primary reasons I don't like shooting with it. If it had a closer MFD, it'd be a phenomenal walk around lens for me... hence, why the 50L is my boo.
135L looks pretty. So does the 50L.
gjl711
Nov 20, 2016 12:47 |  #5
MatthewK wrote in post #18189830 (external link)
Pop in a extension tube.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
CheshireCat
Nov 20, 2016 12:58 |  #6
Uhm... the macro in the second shot is tagged as f/2.8, yet it shows a polygonal bokeh :eek:
1Dx, 5D2 and some lenses
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Post edited over 6 years ago by wallstreetoneil.
Nov 20, 2016 13:09 |  #7
your MFD comments is spot on - you may find the Tamron 85 1.8 works for you - MFD is 2 1/2 ft vs 3ft for the 85L II - that is basically enough that it is never an issue and also co-incidentally, basically equates the DoF at F1.8 at 2 1/2 feet as being equal to the DoF at F1.2 at 3 feet - plus mounting the lens with the rear element not being flush reduces the stress level immensely (and you get weather sealing for street shooting)
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
dochollidayda
Gallery: 40 photos
Joined Aug 2012
Nov 20, 2016 13:37 |  #8
Goodness, the colour out of 135L is gorgeous. 50 has such a unique look, both of them left me salivating. Thanks for sharing these.
flickr (external link) | 500px (external link) | Instagram (external link)
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 20, 2016 22:59 |  #9
CheshireCat wrote in post #18189849 (external link)
Actually once you get to macro distances, even when set to f2.8 , the aperture closes down by itself, the first time I noticed that, I thought my lens was broken.
Also the macro shots display some sort of an extra shadow surrounding the object, any ideas why?
Carpe Diem
(Seize the carp!)
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 20, 2016 23:10 |  #10
The 85L and 135L have a very similar MFD, but the extra 50mm makes a big difference. I do find often that I want to get slightly closer with the 85L, especially because I just got it, and the 50 and 135, let you frame tighter. But for indoor portraits, you can't beat the 85L. Well, unless I want to show more of the environment, then I use the 50mm.
Carpe Diem
(Seize the carp!)
ejenner
Gallery: 98 photos
Joined Nov 2011
Nov 21, 2016 00:05 |  #11
The 100L gets some 'love' as a portrait lens. Yes, it is sharp, but the bokeh is not great, even at 'normal' distances.
I haven't see that shadowing, but I'm usually stopped down at macro distances to get some DOF. Still as I said, bokeh of the 100L is not it's strong point IMO, so it could be that backlight effect combined with the OOF edge.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
CheshireCat
Nov 21, 2016 00:38 |  #12
Moncho wrote in post #18190368 (external link)
It seems to me longitudinal chromatic aberration, very visible due the strong background light creating contrasty silhouette edges.
It is the same phenomenon many call "fringing", visible on tree branches on a bright sky.
This is due to the fact that some light frequencies are not focused on the same plane, and therefore project a different size image on the sensor.
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 21, 2016 04:33 |  #13
ejenner wrote in post #18190394 (external link)
In this case it is the 100mm non L. And I absolutely agree with you, it was my portrait lens, and I was about to upgrade it to the 100L for the weather sealing and IS, but saw a comparison of the bokeh between the 100L vs 135L, and I fell in love with the 135L. Now it just does macro stuff. But for headshots, where f2.8 or f4 is fast enough the 100 macros shine!
Carpe Diem
(Seize the carp!)
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Nov 21, 2016 09:36 |  #14
if you want a rugged type head shot for men, you really can't beat the 100L - sharper is better
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Dec 05, 2016 14:33 |  #15
Thanks for the time but proper framing is key otherwise the telephoto always wins. I bet if you framed that 85 equal to the 135 the 85l would be the strong winner
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
6,198 views & 11 likes for this thread, 10 members have posted to it and it is followed by 5 members.
1605 guests, 139 members online
