I should know this, and it's probably something I overlooked. But...
When I open images in ACR (9.7) some images from the very same camera have the fill, recovery, and brightness. Some don't. Why?
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 20, 2016 20:59 | #1 I should know this, and it's probably something I overlooked. But... Website
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Nov 20, 2016 21:37 | #2 Were they previously processed in LR3 or earlier? Those sliders were from the 2010 process and if an image was processed using 2010 LR won't change it unless you specifically ask it to. LR4,5,6,CC2016 all still contain the old 2010 process engine in case you have an old image you don't want to update. Dan Marchant
PictureNorthCarolina THREAD STARTER Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 21, 2016 00:39 | #3 Dan, thank you for your help. You mention LR but I have never used LR, and don't use it in the new CC install. However, what you say still applies. Until my recent subscribe to CC, I have been using PS CS5 which contains the 2010 process engine. Now that I have a reason, I'll figure out a path. Thanks for your help. Makes sense. Website
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Nov 21, 2016 01:08 | #4 In the Camera Calibration tab, the top item controls the Process Version. However there is a caveat. When you convert an edited image from 2010 to 2012, CR will set its sliders in a way that attempts to recreate the previous editing. It isn't always entirely successful because it can't be. There are some very basic differences between the two PVs and if you regret the conversion, you can"t always go back to exactly what it was before. In LR the usual advice is to do the change over initially on a Virtual Copy, especially if it is an important image. But in CR there are no VCs. I am not sure what the best practice would be using ACR, but some googling around for posts from around the time of the release of PSCS6 should produce some answers. Elie / אלי
PictureNorthCarolina THREAD STARTER Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 21, 2016 01:29 | #5 Elle, Website
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 21, 2016 03:22 | #6 tzalman wrote in post #18190422 In the Camera Calibration tab, the top item controls the Process Version. However there is a caveat. When you convert an edited image from 2010 to 2012, CR will set its sliders in a way that attempts to recreate the previous editing. It isn't always entirely successful because it can't be. There are some very basic differences between the two PVs and if you regret the conversion, you can"t always go back to exactly what it was before. In LR the usual advice is to do the change over initially on a Virtual Copy, especially if it is an important image. But in CR there are no VCs. I am not sure what the best practice would be using ACR, but some googling around for posts from around the time of the release of PSCS6 should produce some answers. There is one way around this issue, if you really wanted to go to the effort, To maintain the old processing all you would really need to do is rename the xmp file, by simply adding an old, or whatever to the end of the filename. It would be nice to see the VCs in Bridge, and there are several different ways you might do them, you could either simply add additional conversions to the same XMP file, or use multiple XMP files, one for each VC. I don't think it would be very difficult to implement the code in Bridge, and we do now have collections/smart collections in Bridge, so who knows maybe Adobe will give us VCs in Bridge too.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Nov 21, 2016 05:39 | #7 Picture North Carolina wrote in post #18190430 Elle, Thank you very much. Very useful info. I am doing mostly landscapes, so if converting from 2010 to 2012 doesn't produce good results, I find that just retweaking settings in 2012 usually ends with better results. I've been playing with some RAWs shot 6 years ago, and so far I am really, really impressed with 2012. Yeah, PV 2012 is great and I remember that when I first started using it I felt like a whole new world was opening up. It took Adobe 9 years to get there (from 2003 to 2012) but there finally was a Raw engine that could approach b/w film tonality. My favorite guru, George Jardine, demonstrates here how just switching from 2010 to 2012 can add as much as three stops of DR: Elie / אלי
PictureNorthCarolina THREAD STARTER Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info Post edited over 6 years ago by Picture North Carolina. | Nov 21, 2016 09:00 | #8 Thanks, Alan. Renaming is not a problem, but another solution may be faster. I'm thinking about creating a sub-directory named OLD XMP and moving them all there. That will create a fresh start on everything. tzalman wrote in post #18190483 Yeah, PV 2012 is great and I remember that when I first started using it I felt like a whole new world was opening up. It took Adobe 9 years to get there (from 2003 to 2012) but there finally was a Raw engine that could approach b/w film tonality. My favorite guru, George Jardine, demonstrates here how just switching from 2010 to 2012 can add as much as three stops of DR: http://www.digitalphotopro.com …/proper-exposure-matters/ and for an excellent tutorial on the nuts and bolts of PV 2012, I highly recommend this: http://www.digitalphotopro.com …r-highlights-and-shadows/ Thanks again, Elle. Good info. And I will check the links. Website
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 21, 2016 14:07 | #9 Picture North Carolina wrote in post #18190577 Thanks, Alan. Renaming is not a problem, but another solution may be faster. I'm thinking about creating a sub-directory named OLD XMP and moving them all there. That will create a fresh start on everything. Thanks again, Elle. Good info. And I will check the links. That additional three stops of DR is exactly what I am experiencing, and the source of my elation. As said, the RAWs are 6-years old. I shot them as HDR knowing the DR of the camera and processing at the time. However, with 2012 I am now finding I can pick a mid-rangeer and pull up and pull down with no clipping on either end, or with mild and acceptable clipping. I am pretty well stunned. I remember reading a few years ago that some lamented a few 2010 controls missing in 2012. I have no idea what their complaints are about. 2012 is hands-down superior to 2010. Brings up a problem, tho. I pre-ordered the new ON1 RAW. At the time I thought anything could be better than ACR 2010. But now seeing the capabilities of the 2012 engine, the ON1 product is going to have to go a lot further to compete. Due out in a few days. We'll see. The real big issue about PV2012 for some people is that for some controls it is auto-adaptive, so that you cannot really be sure what settings are actually being applied to any particular image. So you batch convert, the sliders all get the same numbers, but the actual conversion will differ from image to image. Depending on what you are doing, and how you feel about things, this might not be a good thing; its not too good for something like forensic analysis for example, where you need to be able to account for every transformation applied to the data. If on the other hand all you are concerned with is getting a good looking conversion, and doing it with relative ease, then PV2012 is almost the best thing since sliced bread. I absolutely loved moving to LR4, I did so with the first public beta release, and at that time I was shooting with my old 300D, and it was an absolute wonder, it really gave that camera a new lease of life. I found that 2006 to 2012 was very good, with new RAW converters coming along regularly that improved the camera's usefulness. Considering that the 300D was pre DPP, and the Canon RAW converter absolutely awful, possibly the worse bit of photography software I have ever used. Since 2012 though Adobe hasn't really improved the basic output from the RAW converter, just added new tools etc, although they are very useful tools. It would be nice to see another significant step in RAW output quality, so that I could have a nice camera upgrade for my current 50D. I would consider changing to a different RAW processor, but Capture 1 is too expensive for me to buy as a one off payment, so for now I am happy with Adobe, since I can afford the CC subscription as a hobby cost, and I really like the LR workflow.
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Nov 21, 2016 16:58 | #10 In ACR, why not use Snapshots? One for current process version, one for 2010 or 2003. Dennis
PictureNorthCarolina THREAD STARTER Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 21, 2016 21:01 | #11 Dennis. Thanks. Not familiar with snapshots, but I will look into it. BigAl007 wrote in post #18190813 The real big issue about PV2012 for some people is that for some controls it is auto-adaptive, so that you cannot really be sure what settings are actually being applied to any particular image. So you batch convert, the sliders all get the same numbers, but the actual conversion will differ from image to image. Depending on what you are doing, and how you feel about things, this might not be a good thing; its not too good for something like forensic analysis for example, where you need to be able to account for every transformation applied to the data. If on the other hand all you are concerned with is getting a good looking conversion, and doing it with relative ease, then PV2012 is almost the best thing since sliced bread. I absolutely loved moving to LR4, I did so with the first public beta release, and at that time I was shooting with my old 300D, and it was an absolute wonder, it really gave that camera a new lease of life. I found that 2006 to 2012 was very good, with new RAW converters coming along regularly that improved the camera's usefulness. Considering that the 300D was pre DPP, and the Canon RAW converter absolutely awful, possibly the worse bit of photography software I have ever used. Since 2012 though Adobe hasn't really improved the basic output from the RAW converter, just added new tools etc, although they are very useful tools. It would be nice to see another significant step in RAW output quality, so that I could have a nice camera upgrade for my current 50D. I would consider changing to a different RAW processor, but Capture 1 is too expensive for me to buy as a one off payment, so for now I am happy with Adobe, since I can afford the CC subscription as a hobby cost, and I really like the LR workflow. Alan Alan, Website
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | For your HDR blends I would look at the new RAW HDR option in the latest releases of LR/ACR, by all account it is very good, and you end up with a 32 bit RAW DNG file, so the HDR blend is done before any other processing. I don't usually shoot HDR, but I have tried the RAW Pano tool, and for a 65 image multi row, pano that was shot hand held it produces by far the best results , compared to both the PS tool and MS ICE, again I don't do enough panos to warrant buying specific software. What I liked was that in a scene with a lot of people moving around in groups it attempted to remove as many of them as possible. Again it does the stitching before you do your RAW processing, so what is even better is that you can have the HDR module combine your HDR exposures, then have the Pano module stitch the 32 bit HDR RAWs, so that you effectively start processing from a 32 bit panoramic RAW file as far as actually processing the image goes. I'm planning on going out and deliberately shooting some HDR panos just to test it out. As far as doing batch processes is concerned I believe the whole idea of the auto-adaptive algorithms is to ensure that your batch conversions actually do end up looking the same. LR has a tool called Match Total Exposure, which when applied to a batch of images that were shot at different exposures, say you forgot to change from Av to manual before shooting you pano, it will automatically bring the brightness levels of each image to the same value, although you can end up with all of the images adjusted a bit, it won't necessarily pick one image as the "correct" exposure. I don't think you can do the match exposures with Bridge/ACR though. If it really is an issue then of course you still have the option to use PV2010. Finally in the few occasions where I have shot HDR sets I tend to find that simply using the frame that gives the the correct ETTR exposure will process out and produce just as good a result as running a full HDR blend though PS, since I much prefer a generally natural look.
PictureNorthCarolina THREAD STARTER Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 22, 2016 07:13 | #13 Thank you, Al. I did do a couple HDRs from Bridge / ACR and was surprised by the results. Certainly much better than the implementation in CS5 where it is less than trash. Website
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Nov 22, 2016 08:23 | #14 Picture North Carolina wrote in post #18191138 Dennis. Thanks. Not familiar with snapshots, but I will look into it. Snapshots can be very handy. Say you want to process an image several ways, once you get the image as you want then go to Snapshots, save as a snapshot and give it a name. Go back and process a different version and again save as a snapshot. The processing instructions are saved within the xmp file. Dennis
tonylong ...winded More info | Nov 22, 2016 08:48 | #15 Picture North Carolina wrote in post #18191439 Every where I go (including this thread) people are clamoring about LR. I haven't cranked it up yet. I didn't plan to because of all the horror stories I have read about the cataloging system, but perhaps I'll have to look into it more carefully. It's interesting that a lot of people jump into Lightroom without factoring in the organizational aspect (as in "Digital Asset Management"/DAM)! Tony
| Latest registered member is semonsters 1185 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
