Thread started 21 Nov 2016 (Monday) 08:47
How many of you are using C1Pro compared to Lightroom?
the.forumer
Joined Oct 2011
Nov 21, 2016 08:47 |  #1
I have been a faithful follower of LR since the LR4 days, all the way till 2015.7. Over the years, the app seems to have gotten worse and poorly optimized. Even with 1:1 previews and smart previews pre-generated, there are a lot of micro-lags here and there when browsing/chimping etc.
On the same system, using C1Pro, all of that disappeared - the performance is 100x faster than LR!
The 3 tools I miss most from LR is Upright tool, Vibrance and Dehaze though. Is there by any chance a workaround in C1Pro that I can use to get it back?
Or, is there any chance LR 2016/7 will be properly optimized by then?
cuongduong
Nov 21, 2016 10:53 |  #2
Dehaze: use the Clarity tool. Increase the Clarity and Structure until you get the result that you like. Then under the Exposure tool, increase Contrast a little bit. A lot of time, increase Clarity is all that's needed to reduce haze.
Vibrance: use the Saturation tool under Color Editor, not the one under Exposure. Move it to the right to positive value is Vibrance.
Upright: use Keystone. It's under Composition tool tab.
Hope that helps.
Alveric
Gallery: 38 photos
Nov 21, 2016 12:19 |  #3
And I suggest going easy with the Structure values, especially if you have lots of high frequency areas in your photo. Usually, values of ~3 are enough –any higher and you'll get oversharpening.
the.forumer
Joined Oct 2011
Nov 22, 2016 08:46 |  #4
Alveric wrote in post #18190716 (external link)
1. Clarity and Structure gives very artificial results compared to Dehaze. If used lightly, you can't really tell the difference. In addition, it does not add micro-contrast, unlike Dehaze which can have a pop effect even with subtle +10 additions.
2. Vibrance - thanks! didn't know there's a difference.
3. Keystone - there's no auto upright mode right?
Alveric
Gallery: 38 photos
Post edited over 6 years ago by Alveric.
Nov 22, 2016 08:53 as a reply to  @ the.forumer's post |  #5
Never seen or used Dehaze. I stopped using LR at version 3.x. I don't see anything artificial with Clarity in C1P. Also note that there are four kinds of Clarity, one of which increases saturation (Punch). I normally use Natural, which gives, er, natural results. I hardly ever touch the Structure slider.
Maybe you'd be willing to put a side by side comparison so that we can see the differences between the four kinds of Clarity in C1P and LR's Dehaze?
PS: Punch does definitely look the most artificial of them all.
1,750 views & 1 like for this thread, 3 members have posted to it.
1501 guests, 134 members online
