Thread started 21 Nov 2016 (Monday) 12:12
Should I get the 20mm or 24mm f1.4 to pair with my 85L for events in a dual camera setup.
Moncho
Gallery: 10 photos
Joined Dec 2015
Nov 21, 2016 12:12 |  #1
For events, most likely weddings I have been considering getting either of those 2, I already have the 50mm and consider the 35mm too close a focal length. I already have the 24-105L and a Tamron 21-39mm f2.8, and I find I usually use the wide zoom at its widest setting anyhow. But this sample picture is giving me pause, seeing how much I would need to crop to get even close to 28mm.
Anyone else using a similar setup?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/11/3/LQ_825724.jpg
Image hosted by forum (825724) © Moncho [SHARE LINK]
Carpe Diem
(Seize the carp!)
Bonbridge
Gallery: 20 photos
Joined Jan 2012
Post edited over 6 years ago by Bonbridge.
Nov 21, 2016 14:13 |  #2
If you keep the 50 as the single closest prime I would pick the 24
If you keep the 35 as the single closest prime I would pick the 20
But it still totally depends on what you would like to shoot with it
What you also can do is buy the 24-35/2.0 Art and don't buy a 35 and 20/24
5DII + 6D | 16-35/4.0L IS | Σ35/1.4A | 40/2.8 | Σ85/1.4A | 70-200/2.8L IS II
iMac Retina 5k | i7 | 24Gb RAM | 512GB Flash | 4GB M295X
Website (external link) | flickr (external link) | Instagram (external link)
Sir_Loin
Nov 22, 2016 02:31 |  #3
What Bonbridge said. I have the 24L, 50L and 85L combo and I find it to be a good spread of focal lengths. For anything in between I have the 24-70 f/2.8 MkII and for longer the 70-200 f/2.8 MkII. I've found that I'm not wanting for anything else with that set up.
EOS 1D4, 5D3, EF 24-70mm f/2.8L II, EF 70-200mm f/2.8L II IS, EF 50mm f/1.8 STM, EF 85mm f/1.2L II * EOS R6, RF 24-105mm f/4.0-7.1 * EOS M5, EF-M 11-22mm f/4.0-5.6 IS, EF-M 18-55mm f/3.5-5.6 IS, EF-M 55-200mm f/4.5-6.3 IS, EF-M 22mm f/2.0, EF-M 28mm f/3.5 Macro IS * FL-F 300mm f/5.6 FLUORITE, FD 55mm f/1.2 ASPHERICAL, FD 24-35mm f/3.5L, FD 50mm f/1.2L, FD 300mm f/2.8L, FD 50-300mm f/4.5L
1,796 views & 2 likes for this thread, 3 members have posted to it.
1605 guests, 139 members online
