I come across lot of photographs of water birds from accomplished photographers. Surface of the water will have a beautiful smooth glowing look . Any special PP done to achieve this.
thanks and regards
Anil
sanil Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | Nov 24, 2016 02:19 | #1 I come across lot of photographs of water birds from accomplished photographers. Surface of the water will have a beautiful smooth glowing look . Any special PP done to achieve this. https://www.flickr.com/photos/anilsarvepalli/
tonylong ...winded More info | Nov 24, 2016 02:30 | #2 Do you have a link to an example (post a link, not the actual pic taken by another photographer)? Tony
sanil THREAD STARTER Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info |
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 24, 2016 06:46 | #4 That looks like it was probably taken during the morning golden hour period, in absolutly perfect conditions. I think morning, simply because after the heat of the day it can take a while for the water surface to become mirror smooth. So even though the wind does die away in the evenings, morning is more likely. I'm looking on my phone and couldn't see the EXIF data.
MalVeauX "Looks rough and well used" More info | Nov 24, 2016 08:04 | #5 sanil wrote in post #18193237 I come across lot of photographs of water birds from accomplished photographers. Surface of the water will have a beautiful smooth glowing look . Any special PP done to achieve this. thanks and regards Anil It's about the conditions and utilizing depth of field and the light.
sanil THREAD STARTER Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | Nov 24, 2016 09:49 | #6 MalVeauX wrote in post #18193351 It's about the conditions and utilizing depth of field and the light. Conditions, low to no wind (there's always a little), to avoid obvious waves. This also means little to no surface vegetation to serve to break the water or be a surface for wave reflection. With diffuse early or late light with the sun position not being directly pouring bleaching light down, you get a softer light and the reflections are less harsh and defined too (no major transitions in brightness, darkness, due to reflections or direct sun contact). And depth of field helps a ton, if you are shooting very low, down to the surface of the water, almost all of the surface of the water is out of the depth of field that is in focus, so it softens everything and hides blemishes on the surface, hides movement on the surface, and makes it look like a fuzzy nice mass. Very best, Thank you all. https://www.flickr.com/photos/anilsarvepalli/
DreDaze happy with myself for not saying anything stupid More info | Nov 24, 2016 11:25 | #7 while i somewhat agree with what is posted above...i believe the look you are trying to achieve doesn't really have much to do with the water reflection... Andre or Dre
sanil THREAD STARTER Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | Nov 24, 2016 19:46 | #8 Dear Anil, this effect comes not by processing, but by photographing. The secret is you have to put the camera as low as possible nearly touching the water surface. You can manage this in different ways. On a ground tripod near the lake and you have to lay down and hide yousrelf or the other way is to build a floating hide and go into the water with your construction. Search on the internet with "floating hide", you will get some information and images. Best regards Hans.. https://www.flickr.com/photos/anilsarvepalli/
| Latest registered member is semonsters 1674 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
