With all the white balace tools out there I am looking for opinions as to which tool provides the best out come when doing in camera WB. 18% gray or the one's you place against your lens.
Nov 24, 2016 07:08 | #1 With all the white balace tools out there I am looking for opinions as to which tool provides the best out come when doing in camera WB. 18% gray or the one's you place against your lens.
ksbal Goldmember More info Post edited over 6 years ago by ksbal. (2 edits in all) | Nov 24, 2016 07:23 | #2 To set exposure and then WB, particularly wihen working with strobe or flash: Godox/Flashpoint r2 system, plus some canon stuff.
PhotosGuy Cream of the Crop, R.I.P. More info | Nov 24, 2016 07:44 | #3 For me, it depends on what I'm shooting, & I always use RAW. For a product shot, I want the neutral WB & would use a Custom WB. But outdoors I might use a pre-set for daylight because I want to keep the warm colors of a late light image. FrankC - 20D, RAW, Manual everything...
Nov 24, 2016 08:03 | #4 I am hoping to use it for the most part when I'm shooting portrait with my streaklights. It seams more often then not my shots are on the cold side and need to be warmed up all the time. Thinking custom white balance should help my workflow a bit. Thanks for the comments.
Nov 24, 2016 09:04 | #5 ksbal wrote in post #18193330 which reminds me, dog ate the 14inch one and I should try to find a black friday deal to replace it! Replace the dog or the target that it ate?
ashleykaryl Member 204 posts Likes: 70 Joined Aug 2009 More info Post edited over 6 years ago by ashleykaryl. | Nov 24, 2016 15:15 | #6 jlstan wrote in post #18193350 I am hoping to use it for the most part when I'm shooting portrait with my streaklights. It seams more often then not my shots are on the cold side and need to be warmed up all the time. Thinking custom white balance should help my workflow a bit. Thanks for the comments. In the other thread you started on this subject we mentioned the ExpoDisc that can be used to set a neutral white balance, but it comes with gels that can be used to tweak the white balance towards a warmer setting for nicer skin tones. They used to make a separate Expodisc specifically for this task that I have. X-Rite Coloratti Pro, Phase One Ambassador
Leaning towards the color checker. Thanks for all the input thus far
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Nov 25, 2016 11:40 | #8 Simple White Balance for most folks is quite well handled with a simple grey card. If you need Color CRITICAL accuracy, using the Colorchecker Passport, and profiles for specific lighting circumstances helps to meet the need. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Nov 25, 2016 14:57 | #9 Permanent banColour card. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
ksbal Goldmember More info | *LOL* just the target.. I was the dummy that left it on the grass, so not their fault. Godox/Flashpoint r2 system, plus some canon stuff.
| Latest registered member is semonsters 1215 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
