I shoot anything that does or does not move.
I can finally upgrade to full frame.
5dmk4 4400 bucks
5dr 4600 bucks
200 bucks is no issue. Which one?Why?
Thanks, Eric
Nov 24, 2016 08:20 | #1 I shoot anything that does or does not move.
MalVeauX "Looks rough and well used" More info | Nov 24, 2016 08:30 | #2 Need more info than that.
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Nov 24, 2016 08:44 | #3 Permanent banFull frame is not always an upgrade. Depends on what you plan to do with it. If you just need a really good, do-it-all camera, I'd suggest a serious look at the 5D3. I don't own one, primarily because I don't need a really good, do-it-all camera. I muddle through with 2 (3 tomorrow!
Nov 24, 2016 09:10 | #4 Really was not looking at res but whether 5dr is worth 200 extra bucks for other features.
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Nov 24, 2016 09:13 | #5 Permanent banfilmuser wrote in post #18193404 Really was not looking at res but whether 5dr is worth 200 extra bucks for other features. That is beyond me. I don't see the point of either of those cameras.
MalVeauX "Looks rough and well used" More info | Nov 24, 2016 09:35 | #6 filmuser wrote in post #18193404 Really was not looking at res but whether 5dr is worth 200 extra bucks for other features. If you're not needing the resolution, then what reason is there to look at the 5DR? That's the deep question that will help you separate the two.
Nov 24, 2016 09:56 | #7 I can't imagine there's a better do all camera then the 5D4. Canon R6M2
LJ3Jim Goldmember More info | Nov 24, 2016 10:29 | #8 For the things that move, the 5D4. It has Canon's latest AF system, which is excellent. Image editing ok; C&C always welcome.
mesakid Senior Member 364 posts Likes: 17 Joined Dec 2010 More info | Nov 24, 2016 13:53 | #9 I don't know your situation, but go with the 5DIV if those are the two you're deciding on. https://www.youtube.com/that1cameraguy
Nov 25, 2016 07:02 | #10 So the mk4 has better innards the 5ds. Sounds like a plan.
spillcanvas24 Member 54 posts Likes: 2 Joined Feb 2016 More info | Dec 22, 2016 17:00 | #11 I'd go with the 5dmIV personally. Beautiful camera, superior quality, does the trick every time
TeamSpeed 01010100 01010011 More info Post edited over 6 years ago by TeamSpeed. (2 edits in all) | Dec 22, 2016 19:04 | #12 spillcanvas24 wrote in post #18220971 I'd go with the 5dmIV personally. Beautiful camera, superior quality, does the trick every time Given your post history in the last 2 hours, something seems a bit odd in your replies... spillcanvas24 wrote in post #18220933 This camera (the 5D4) looks beautiful. Is this top of the line? Past Equipment | My Personal Gallery
Dec 26, 2016 07:31 | #13 If you shoot everything, especially stuff that moves the 5D MK4 is an all round camera, get it for an all-round photographer. The 5d R is better for studio and landscape, stuff in good light primarily that does not require a high from rate. There are people using the 5d R for BIF but this is a limited use. I try to make art by pushing buttons
TeamSpeed 01010100 01010011 More info | Dec 26, 2016 07:40 | #14 The 5d4 is better with DR thus a better landscape camera in some conditions. It also handles higher ISO better. Past Equipment | My Personal Gallery
digitalparadise Awaiting the title ferry... More info Post edited over 6 years ago by digital paradise. | Dec 26, 2016 08:16 | #15 I actually ordered the 5DRS and cancelled it. I had a hard time deciding which path to take. I wanted the resolution for cropping but was not sure I wanted a specialized camera. I've seen nice BIF shots with it but I figured the success rate might be hindered. 1. I get all 61 AF points with my 100-400 II and 1.4 III. I love to use all the AF configs and Case numbers when I shoot and I not yet convinced Cases 5 and 6 do much for me unless I am using one of the zone AF modes. I'll be using that combo a lot more now. 560mm is a good compromise between a 500 and 600L. As you can see from some of my posts the IQ is good with extreme crops. 2. The focus is very snappy even with the TC. When I was testing on the birds on the shots I was taking I was impressed. Can hardly wait to try BIF. 3. Case number parameters have more steps for fine tuning. Identical to the 1DX II. 4. The 5D4 has a separate AF area selection button just beside the multi-controller button. The 7D2 had it as part of the multi-controller button. If Canon had offered it as a retro for my 5D3 I would have paid to have it installed. I paid to have Canon install a locking mode dial retro on my 7D. 5. I did not really consider it but the touch screen is pretty amazing. I can whip through the menus. I barely use the green my menu's now. When I pick up my 7D2 I find myself tapping the screen. 6. When you press the Q button you get the Q screen. Press info and a second Q screen comes up that shows all the AF points, ISO etc and you can program more things you want to see when you open that screen. 7. I have been shooting at 32,000 ISO and getting good results. 8. The 5D4 offers the Detail Set when you are programming the AF-ON and * buttons. I wish Canon would add Drive Mode here. So all around it has everything my 7D2 has that I wish my 5D3 had, more megapixels, better high ISO, better AF than both 5D3 and 7D2 and it is FF. Image Editing OK
| Latest registered member is semonsters 1522 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
