I shoot exclusively in Aperture mode. I feel that shooting in manual mode may open up some possibilities. How do i Start doing it ? Any suggestions / Methodologies?
Thank you
Anil
sanil Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | Nov 28, 2016 06:51 | #1 I shoot exclusively in Aperture mode. I feel that shooting in manual mode may open up some possibilities. How do i Start doing it ? Any suggestions / Methodologies? https://www.flickr.com/photos/anilsarvepalli/
PhotosGuy Cream of the Crop, R.I.P. More info | Nov 28, 2016 09:52 | #2 You shoot a lot of birds, so I assume that you don't want to manual focus, but use M for exposure? I use my hand as the known target + a 4/3 compensation in the viewfinder: FrankC - 20D, RAW, Manual everything...
Archibald You must be quackers! More info | Nov 28, 2016 10:00 | #3 sanil wrote in post #18196779 I shoot exclusively in Aperture mode. I feel that shooting in manual mode may open up some possibilities. How do i Start doing it ? Any suggestions / Methodologies? Thank you Anil Many of us shoot M mode with auto ISO. It gives full control over aperture and shutter speed. ISO is usually a less critical parameter with today's excellent sensors, plus there is noise reduction in post-processing. Give it a try. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
LarryJohnson Goldmember More info Post edited over 6 years ago by Larry Johnson. (2 edits in all) | Nov 28, 2016 10:26 | #4 Good choice. I never understood why people shoot in AP mode. _______________
MalVeauX "Looks rough and well used" More info | Nov 28, 2016 10:52 | #5 sanil wrote in post #18196779 I shoot exclusively in Aperture mode. I feel that shooting in manual mode may open up some possibilities. How do i Start doing it ? Any suggestions / Methodologies? Thank you Anil Heya,
sanil THREAD STARTER Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | Nov 30, 2016 10:49 | #6 Shall try shooting in manual mode and post some pictures ... later this week. https://www.flickr.com/photos/anilsarvepalli/
Archibald You must be quackers! More info | Nov 30, 2016 11:14 | #7 sanil wrote in post #18199145 Shall try shooting in manual mode and post some pictures ... later this week. One of the techniques i read else where and tried.. to take metering of grass in the same light as the bird .. null the meter .. to begin with... then if the bird is white ... under expose by couple of stops and if the bird is dark over expose by couple of stops.. .. if the light become brighter increase the no of stops ... i was shooting birds flying on the water (which is lit bright with sun) and had miserable results.. could nt figure out why? Just watch for blinkies. If there are blinkies, then reduce the exposure. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info Post edited over 6 years ago by John Sheehy. | Nov 30, 2016 11:18 | #8 sanil wrote in post #18196779 I shoot exclusively in Aperture mode. I feel that shooting in manual mode may open up some possibilities. How do i Start doing it ? Any suggestions / Methodologies? Auto-ISO in M mode with HTP (Highlight Tone Priority) enabled is my go-to. HTP gives a stop of headroom for when you don't have time to perfect the embedded JPEG exposure, and does not give horrific shadow results with newer cameras with lower banding noise when HTP causes very low ISOs, especially newer cameras with the off-sensor ADC.
sanil THREAD STARTER Senior Member 658 posts Likes: 1561 Joined Mar 2006 Location: Hyderabad - Deccan More info | no blinkies were there during that shooot.. while I was photographing .. in manual mode.. https://www.flickr.com/photos/anilsarvepalli/
There are two methods for metering; 1. metering your white subject, 2. metering off of something neutral gray (i.e. grass) and then adjusting up or down depending whether your subject is light or dark. The "ah ha" moment for me regarding metering and learning how to shoot in manual mode was learning that, when in any auto mode, the camera will make all of your images neutral gray (or approx. 18% gray). Read Sandpiper's explanation in this thread; https://photography-on-the.net …/showthread.php?t=1371483 _______________
Archibald You must be quackers! More info | Nov 30, 2016 11:26 | #11 John Sheehy wrote in post #18199174 Auto-ISO in M mode with HTP enabled is my go-to. HTP gives a stop of headroom for when you don't have time to perfect the embedded JPEG exposure, and does not give horrific shadow results with newer cameras with lower banding noise when HTP causes very low ISOs, especially newer cameras with the off-sensor ADC. Keep your Av value wide open, unless you need DOF or your lens is sharpest stopped down a little; adjust shutter speed a little bit depending on lighting, with the knowledge of how the lighting drives the ISO at that shutter speed, to help decide with trade-offs. Even though my ISO might vary from 200 to 16,000 (7D2 ISO range for HTP), my aperture generally only varies by a stop or so and is almost always wide-open, and shutter speed is set for lighting and subject activity, but generally over a much smaller range than ISO. With a relatively calm bird in shade, I might drop to take a few shots at 1/100 or sometimes slower. Out in the sun, and with BIFs, shutter speed can be 1/800 to 1/2000. You have to be careful about leaving the camera set to slow shutter speeds from the shade when you move to bright areas, though, as that can cause blown ISO 200 images. Unfortunately, the cameras don't seem to have a shutter speed escape option to raise the shutter speed when it would cause over-exposure. Eventually, we should have enough flexibility in settings that we can pretty much define what the Av, Tv, and ISO settings are for a range of light levels, and make the camera do what we would do if we had the time to do it. I'm sure everybody knows what HTP means... Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Nov 30, 2016 11:33 | #12 Larry Johnson wrote in post #18196903 Auto ISO is NOT manual mode. The camera will still make decisions for you in this mode. I disagree. Auto-ISO with manual Av and manual Tv is as "Manual" as it gets, because you are never compromising those two manual setting to adjust relative "exposure". Aperture determines real photographic parameters, and the exposure time does, too. "Exposure" and "ISO" are semantic/logistic nuisances that interfere with true manual photography, which is what you would have if you had a camera with no variable "gain" per se; just a photon-counting sensor and Av and Tv controls, where there is only absolute exposure, and no relative under- or over-exposure. No highlight clipping possible, and no low exposure issues other than shot noise, the texture of captured light.
PhotosGuy Cream of the Crop, R.I.P. More info | Nov 30, 2016 11:58 | #13 John Sheehy wrote in post #18199186 I disagree. Auto-ISO with manual Av and manual Tv is as "Manual" as it gets, because you are never compromising those two manual setting to adjust relative "exposure"... I totally disagree. Anytime the camera chooses to adjust the exposure, it's not what we mean when we say "Manual exposure". FrankC - 20D, RAW, Manual everything...
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Nov 30, 2016 11:58 | #14 Archibald wrote in post #18199182 I'm sure everybody knows what HTP means... I edited my post to spell out HTP (Highlight Tone Priority).
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Nov 30, 2016 12:04 | #15 PhotosGuy wrote in post #18199212 I totally disagree. Anytime the camera chooses to adjust the exposure, it's not what we mean when we say "Manual exposure". Exposure on the sensor is not changed by the ISO setting in M mode. The ISO setting only changes the absolute clipping level, and the amount of post-gain noise added to the signal in readout. These are not real photographic parameters; they are technological problems forced onto manual-TV&Av photography.
| Latest registered member is semonsters 1674 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
