djr81 wrote in post #18199755
Both were the HD filter. They were just by way of an example to show - in the case of the second shot you can get a half decent result in low(ish) light and exposure compensation on the camera. The first shot was just about ok because of the clouds cover. In direct sunlight it all just blows out.
That's what you would expect. The CPL gives a max of about 2 stops of "dimming", which is not so handy in the bright daylight!
I cant comment on the filter "dialling" I just picked them out of their packets and plonked them on the desk. They are both CPL's the first noticably darker than the second.
Have you read the info/instructions on using the CPL? I don't have those two models, but as far as I know CPLs as a whole have the rotating/dialing design -- you rotate the ring and the effect shifts as you do.
The difference between the two in your shot would be because the darker one had been rotated for more of a max effect.
This is all probably heading toward me buying an ND filter at some point.
Yeah, if you are after that stuff, then the ND is the way to go.
An old "tradition" is to use a Graduated Neutral Density (GND) filter that will darken down a light sky so that darker things in the foreground will get a better exposure. You can in fact get good results from that approach, although in these days of shooting digital Raw, with the Raw files/data having a greater dynamic range that is adjustable, and also with the High Dynamic Range (HDR) approach, well, GND filters are not as popular as they once were.
With regard to the combination do you have one screw on and a second plate type out in front?
I'm not sure about what you are asking here: a combination of more than one CPL filters, or a combination of more than one ND filters, or???
