Thread started 02 Dec 2016 (Friday) 18:35
Godox X1C not Firing my 580exii
nicshow
Dec 02, 2016 18:35 |  #1
I just got the Godox X1C kit. My 580 exii won't fire with it. The test button does activate the flash and turning the wheel changes the settings on the flash. I've updated the firmware to the most current version. Any help would be appreciated!
Nic
http://www.flickr.com/​photos/nicshow/ (external link)
http://www.nicshowalte​r.com (external link)
agv8or
Gallery: 10 photos
Post edited over 6 years ago by agv8or.
Dec 02, 2016 19:40 |  #2
Does the firmware version in the Receiver match the firmware version in the transmitter? When I tested the 580EX II in different receivers, with different firmware versions, I had issues when the receiver firmware did not match the transmitter.
Rand
Gear
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 6 years ago by CyberDyneSystems. (2 edits in all)
Dec 04, 2016 00:11 |  #3
Other than that, be sure to triple check the screw lock down and hot-shoe alignment.
One real drawback I find of the Godox big plastic lock down "nut" is that as you apply that last bit of pressure they sometimes want to push the male end out of the female end of the hot-shoe assembly. This can easily = bad pin alignment.
For the record i just retested this same set up with my 580EXII and X1 t and receiver, and I got both test and accurate ETTL exposure. (on 7D2)
CDS' HOT LINKS
nixland
Dec 04, 2016 02:03 |  #4
CyberDyneSystems wrote in post #18202653 (external link)
I second Cyber about checking pin alignment, and also clean up the pin. Because it also happens often with my Yongnuo YNE3RX receiver on 580EXII.
nicshow
Dec 09, 2016 12:10 |  #5
In case it's helpful, on a whim I ordered the Godox manual flash and a different set of transceiver/receiver.
So I tried to use the new manual flash with the trigger and somehow/somewhere in the configuring...the 580exii started to work with the trigger. I have no explanation of why.
When I received the new set (Flashpoint this time) I decided that if the new set fired the 580exii the first time, I would keep that set and return the first set. It worked and so I'm returning the Godox set.
I am now, however, having trouble updating the firmware in the receiver - keep getting an error message.
The new trigger, however, does fire both the older Canon with the X1R-C attached AND the Godox flash.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Dec 10, 2016 00:08 as a reply to  @ nicshow's post |  #6
As it should! Sounds like a bad trigger. Glad the new one is working.
CDS' HOT LINKS
3,050 views & 1 like for this thread, 4 members have posted to it.
1036 guests, 107 members online
