Here is a late processing of a widefield target from earlier this fall. This field contains two major galaxies The Andromeda Galaxy(M31) and Triangulum galaxy (M33).
The IFN "integrated flux nebula" is a very faint intra galactic dust cloud which reflects light emitted by our milky way. IFN and ISM, interstellar medium, can be spotted sweeping across vast areas of our skies amongst the more open regions of our milkyway sky. There are several surveys which have mapped out the IFN which can be very helpful for identifying faint structures. It is very difficult to discern between gradients and ifn when processing structures this faint. I was able to pull a strong luminance image from the green channel and bring out the faint nebulosity by blending with the original iamge.
Sky Mag: 21.2
Integration: 70 x 90s subs at iso 1600, 105 minutes total integration
Calibration: 25 Darks 35 flats 800 frame master bias
Camera: full spectrum T2i and astronomik uv/ir cut clip filter.
Lens: pentax-m 50mm F1.7 stopped to F4
Calibrated in Pi and processed in PS CC
