Thread started 12 Dec 2016 (Monday) 10:51
Firmware Update problem with Godox TT685S and X1Ts - Help requested
jmaher
Gallery: 20 photos
Dec 12, 2016 10:51 |  #1
I am unable to update either of the above units. I have the new G1 software. I have tried to update these on 3 different Windows 10 machines and tried 3 different USB cables on each of them. I get the same error message whatever I do. It's always "Connect failed". Any suggestions?
Jim
jmaher
Gallery: 20 photos
Dec 14, 2016 15:30 |  #2
Doesn't anyone have an idea of what I could do differently or hss encountered this problem and fixed it somehow?
Jim
dmward
Gallery: 29 photos
Dec 15, 2016 02:02 |  #3
jmaher wrote in post #18213197 (external link)
Jim
Jim,
I haven't had a chance to update my Sony variant TT685 or XiT devices.
I'm traveling -- give it a try when I get home on the weekend.
The problem you describe is, as I understand it, a USB driver issue.
I am a MAC user, but got a Windows 10 Thinkbook to deal with firmware updates. The few I've had to do with the G1 software have worked with out a problem. Prior to it, I did have some connection problems because drivers where in the wrong place.
jmaher
Gallery: 20 photos
Dec 15, 2016 07:55 |  #4
Thanks for the response. I believe it most likely is a USB connection or driver issue. I suspect the TT685 and Xits are not being seen by the computer system. However I don't know what to do about that. That's why I tried ore than one C and more than one cable. Turned the devices off as in the instructions, etc. Very frustrating.
dmward
Gallery: 29 photos
Dec 17, 2016 18:01 |  #5
I updated the two TT860IIs speedlites I have this afternoon.
I found that I had to have the proper firmware selected before the G1 software would recognize the speedlite once that was accomplished it worked like a charm.
I did one with the battery removed and the speedlite turned off. The second one with the battery installed but turned off.
Both ways worked.
jmaher
Gallery: 20 photos
Dec 17, 2016 22:30 |  #6
David,
Thanks for the followup. I am sure I had the correct firmware selected prior to attempting the upgrade but I will try it again tomorrow and make sure that was done.
Jim
dmward
Gallery: 29 photos
Dec 17, 2016 22:35 |  #7
jmaher wrote in post #18216206 (external link)
David,
Jim
Jim,
You probably did. I thought so too initially then discovered that I was point to a zip file rather than just the firmware file.
It appears that the G1 software, Windows 10 UBS drivers and the other elements have a very precise and peculiar linkage that has to be set just the way some programer determined. One thing out of place and it doesn't work.
agv8or
Gallery: 10 photos
Post edited over 6 years ago by agv8or.
Dec 18, 2016 22:35 |  #8
Well do not feel alone as I am having issues with trying to update Godox firmware on my new Windows 10 Lenovo Laptop. I just did numerous Phottix firmware updates a couple of nights ago and had no issues.
I have tried everything to get this laptop to work with the G1 software and recognize the attached device. I have uninstalled and reinstalled the G1 software as well as went into the G1 files and reinstalled the USB drivers, all with no luck even though I am getting confirmation that the software and drivers have down loaded successfully. I even uninstalled the antivirus software, that came with the computer, as that is usually an issue I've had on other computers and still no go.
I did figure out that one of the TT685's I was trying to update has a bad USB port because it will not work on either my new laptop or my XP desk top. Of course it was the first one I was trying to update and it left me bewildered why my XP machine was not recognizing it. A little bit of time wasted there but I was able to load the firmware on all the rest of my devices, with my XP machine, no matter which order I hooked up the device or opened the G1 software. I would make sure that the G1 software would connect to the device on the XP machine and then go over to the laptop with the device and cable where I would get connection failure, when I told the software to connect.
So I am at a loss as to what is going on. I had both of my dedicated Photography computers fail in the last few weeks, hence the new laptop but it looks like if my old everyday clunker XP machine fails then I am SOL.
Rand
Gear
jmaher
Gallery: 20 photos
Dec 20, 2016 17:40 as a reply to  @ agv8or's post |  #9
Tried again with no luck. Going to try it on a friends computer - maybe tomorrow.
hemal
1 post
Joined Apr 2017
Apr 25, 2017 01:41 as a reply to  @ jmaher's post |  #10
I have the same issue. Tried all the variations still unable to update the firmware.
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Apr 25, 2017 01:54 |  #11
I have never had this particular problem, but have had similar problems with other devices with the same type of USB cord.
The problem I had was in the USB cord I tried to use. I used one that was from a cell phone. What I did not realize is that the cord was not a true USB cord but was a cord that contained only the connections necessary for charging the phone. I am only mentioning this to be sure you are not having the same problem. Just make sure the cord you are using is a full function cord that has all the connections and not one that is from another device that is not capable of performing data transfers.
Philip
Figtreephoto
Gallery: 39 photos
Apr 26, 2017 20:17 |  #12
I am having the same exact connection problem updating my X1R- receiver. Does anyone know if it is possible to obtain the Godox_USB driver that appears to be required for a connection either from Godox directly or by someone has has updated successfully?
Joel
kenwood33
Mar 08, 2020 17:08 |  #13
I am also trying to update the firmware on the X1-T trigger without any success. I followed the instruction on the following link, but keep getting connect fail like the OP did. After almost 4 years, I m curious if anyone has found a solution? I m using a windows 10 laptop, have successfully installed the G1 software without any errors. When I connect the X1-T trigger to the laptop, there were no indication that windows was able to recognize it - no display on the trigger, no new device found etc.. Really don't want to update anything but I m 10+ versions behind.
http://flashhavoc.com …rocedures/comme​nt-page-2/ (external link)
Gearlist
inkista
Mar 08, 2020 19:49 |  #14
Someone on dpreview mentions disabling driver signing (external link).
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
bitse
1 post
Joined Jun 2021
Jun 20, 2021 09:44 |  #15
Hi all,
I had similar issue but resolved after connecting in USB 2.0 port.
Based on my experience it could be due to two reasons
* USB Cable issue
* USB Port
Suggest to try with different cable or port. It didnt work with USB 3.0 and make sure to reboot the machine after drivers & upgrade software installation.
15,491 views & 0 likes for this thread, 10 members have posted to it and it is followed by 5 members.
1626 guests, 142 members online
