FORUMS General Gear Talk DIY & Customizing
Thread started 17 Dec 2016 (Saturday) 02:18
DIY Astrophotgraphy Hinge Tracker
gmm213
I know some really nice clowns
Joined Apr 2013
Dec 17, 2016 02:18 |  #1
Ok so I am just looking at getting into astrophotography. I am not sure if this is helpful or a good design but I figured Id throw it out there. http://garyseronik.com …ker-for-astrophotography/ (external link)
500px (external link)
Mayhem # 3789333 (external link)
shane_c
Dec 26, 2016 14:42 |  #2
I'm interested too so I hope there are some replies.
Canon R5 - Canon RF24-105L F4, Canon 40mm, Canon 70-200L F4 (non-IS), Canon 100-400ii, 1.4xiii
G1X MK2, G15
My Instagram (external link)
Roy ­ A. ­ Rust
Rest peacefully in the Celestial infinity
Gallery: 229 photos
Joined Dec 2015
Post edited over 6 years ago by Roy A. Rust.
Jan 05, 2017 07:21 |  #3
That thing will work, but you will probably waste a lot of time and delete a lot of pictures that don't turn out well. I made three of them, and used them until I found out that there were commercially made trackers available. I ordered an iOptron Sky Tracker, and my Scotch Mounts (hinged trackers) have been gathering dust in the garage ever since. While it will track the stars if the calculations are right, it takes a lot of concentration and patience to use it. Aligning it is pretty much just ball-park alignment, at best, and if you have a manually operated one, like the one you referenced, you will likely introduce vibrations and blurred stars when using it.
The length from the hinge to the drive screw must be compatible with the thread spacing on the rod that drives it. I think I still have the calculations I used for a 1/4" x 24 threaded rod, or I could measure the one in the garage if you want. But if you can afford it, I would strongly suggest you buy a commercially made tracker and a really sturdy tripod to support it. Regular camera tripods with an adjustable center column are too flexible, and not solid enough.
Here's the final one I made, and a photo of the Milky Way I took with it before I learned about the commercial tracker I use now. I happened to have a chronographically controlled motor I used to drive it. My first one was manually rotated, like the one in your referenced link. Some of my more recent images, using the iOptron tracker are posted on POTN. I can easily take 10 to 15 minute exposures with it.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/1/LQ_832977.jpg
Image hosted by forum (832977) © Roy A. Rust [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/1/LQ_832978.jpg
Image hosted by forum (832978) © Roy A. Rust [SHARE LINK]
2,115 views & 1 like for this thread, 3 members have posted to it and it is followed by 3 members.
1502 guests, 133 members online
