I've owned the RL600B for just a little over a year, so it's not in warranty, which I think would include the cheapo Remote RR-RL600V2. I've only used it 3 times. Well the other day, Christmas Eve while setting up to do some portrait, photo-booth type shooting the remote decided to go on vacation. I couldn't get it to work. Fresh battery in it. I tried using the reset button, and removing and replacing the battery. Then the red light on the front, between the dipswitches & Power/Flash-Test button, comes on, stays on flickering rapidly. Still it would not communicate with the monolight. Both the monolight and remote were set to the same channel (dipswitch on remote and RL screen matching). Finally just pulled the battery out of the remote. I've played with it since then and still nothing. So I'm thinking this cheap remote is done. I looked on Adorama's site and seen it costs $14 for a new one. Do I really want to go there?
Ok with that said, I have the one RL 660B, which I use with my 43" EZ Pro Softbox. I've been putting one of my YN 600c transceivers on it, plugged into the sync port. That way I can trigger it with my YN 600-TX on my camera. I also have 3 YN-685c Flashes, that of course have the built in receivers. So my only use for the cheap RL Remote is changing the settings on the RL. The other day I had to drop the RL down, or drag a chair over to it to stand on to change settings. Thankfully this was for family, and not a real working gig.
Now, comes my question(s);
I noticed Adorama has a couple of different receivers and transmitters listed.
1. Flashpoint R1 HSS Remote Transceiver for Canon (CELLS IIC)
. I'm not sure if this would allow changing the settings on the Rovelight through the camera's menu, or what. I don't see any way on the unit to do that.
2. Flashpoint R2 E-TTL Transmitter for Canon Cameras (X1T-C)
. This unit does have a LCD menu on it.
I know they're not going to talk to my YN685 flashes, but like I said, I can handle that with my -TX unit. It looks like I'd be able to somehow attach the -TX on one of the above. With the TX unit I don't use my camera's menu, so I'm worried about that for the flashes. I need some way to control the Rovelight when I use it with my flashes.
Which would be recommended, #1, #2, or just by the cheap replacement that will more than likely fail soon after ?
