Since I do something like 97.5% of my image editing exclusively in LR, with RAW files, I also routinely apply my crops for composition at the same time, since I also use LR as my main image viewing application. If I have to send a file off to PS for additional processing, or to add some other "artistic effects" I will send to PS before I crop, or in the case of an "artistic effect" I will create a VC and remove the crop to send the image to PS. I then ally the crop to the PSD file back in LR, or if it was from a VC I may even copy the crop across from the original version. This way, if I need to change the aspect ratio for some different output need, such as fitting to a desired paper size, I have all of the pixels still to call on.
Of course the point is that in LR cropping is not really cropping, just a serving suggestion.
Alan
