Thread started 28 Dec 2016 (Wednesday) 22:05
Blue Screen of Death
Littlejon ­ Dsgn
Joined Feb 2012
Post edited over 6 years ago by Littlejon Dsgn.
Dec 28, 2016 22:05 |  #1
While using LRCC latest updates I am getting constant BSOD's I can only edit a couple pictures after launching LR before everything crashes and restarts.
Windos 10 Home
Lenovo Laptop i7-4510U, 16GB Ram .... not sure what other info would be needed to help get to the bottom of this.
BSOD's read the following (several different readouts)
Stop Code: PAGE_FAULT_IN_NONPAGED​_AREA
Stop Code: KERNEL_SECURITY_CHECK_​FAILURE
Stop Code: IRQL_NOT_LESS_OR_EQUAL
Stop Code: QUOTA_UNDERFLOW
Stop Code: POOL_CORRUPTION_IN_FIL​E_AREA
theres more every time it feels like its a different stop code.
I have also just rolled back LRCC to update 6 vs the 8 or 8.1 that is currently the newest update. I did not have any problems while editing weddings over the summer so thinking it might be more of a LR issue.
John ­ from ­ PA
Joined May 2003
Post edited over 6 years ago by John from PA.
Dec 29, 2016 07:46 |  #2
Software usually doesn't cause a BSOD but rather a crash of the software causing the issue. It is far more likely that it's a driver or some sort of hardware related issue. I'd start with the steps outlined at https://support.micros​oft.com/en-us/kb/2641432 (external link) and run a disk check. The outlined steps are for Windows 7 but should be very similar for Win 10.
Jethr0
Gallery: 91 photos
Joined Aug 2012
Dec 29, 2016 07:52 |  #3
What is the stop code?
It will be the number that starts with 0X000####?
www.jefflowe.ca (external link)
Instagram: https://www.instagram.com/jeff​lowe.ca (external link)
BigAl007
Gallery: 556 photos
Dec 29, 2016 09:36 |  #4
I know it's not supposed to be able to happen any more, what with modern memory management systems etc, but it makes me think of a rogue pointer hitting memory addresses it shouldn't have access to. They could be very good at giving you a different point of failure every time you run the thing, or even no failure on some runs. I found I was quite good at creating them back when I was learning C programming on DOS 5/6 and Win 3.1. How's using the rolled back version of LR? Have the issues gone away, or are you still getting the BSODs? It's probably worth running the memory tests, and maybe also checking the HDDs too anyway even if the rollback seems to have solved the issue.
Alan
aphphoto
Joined Nov 2010
Dec 29, 2016 10:01 |  #5
Blue Screen View (external link)
Who Crashed (external link)
who gives a rat crap how much gear you can list?
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 10:02 |  #6
John from PA wrote in post #18226340 (external link)
Thank you that is a step I have not taken yet, I will do so this evening.
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 10:03 |  #7
Jethr0 wrote in post #18226344 (external link)
The blue screens do not have a number on them, I think I remember those from windoes 7 but not on 10
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 10:04 |  #8
BigAl007 wrote in post #18226451 (external link)
Alan
As of this morning LR was still humming away, I have not had a chance to start any major editing since I rolled it back, I will be doing so after work today.
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 10:05 |  #9
On another note I did spend the better part of an evening last week updating every driver I could so everything on that end should be up to date.
Jethr0
Gallery: 91 photos
Joined Aug 2012
Dec 29, 2016 11:02 as a reply to  @ Littlejon Dsgn's post |  #10
Oh, didn't know that. Last PC I had in the house was win7.
The stop number should at least be in the system event log.
SailingAway
Joined Sep 2013
Dec 29, 2016 18:09 |  #11
Littlejon Dsgn wrote in post #18226496 (external link)
These updates were *prior* to your BSODs?
If that's true, and BSODs continue, I'd suspect graphics card drivers, and look for a rollback there.
From the upper left corner of the U.S.
Photos, Video & Pano r us.
College and workshop instructor in video and audio.
70D, Sigma 8mm, Tokina f2.8 11-16, Canon EF-S f2.8 17-55, Sigma f2.8 50-150 EX OS, Tamron 150-600VC. Gigapan Epic Pro, Nodal Ninja 5 & R10.
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 18:10 as a reply to  @ SailingAway's post |  #12
These updates where as I was trying to fix my ongoing BSOD's, however it did not fix the problem.
Jethr0
Gallery: 91 photos
Joined Aug 2012
Dec 29, 2016 18:13 |  #13
I suggest back up of files the format and rebuild. You can troubleshoot forever.
Littlejon ­ Dsgn
Joined Feb 2012
Dec 29, 2016 18:18 |  #14
Jethr0 wrote in post #18227041 (external link)
Its getting to that point, my files are all now on external drives, I thought maybe the internal drive was just to full. If this rollback of LR updates does not work I will be reformatting the computer. Not entirely sure how to do that at this point, last time I did that was back when you were given CD's with the computer for doing just that.
Jethr0
Gallery: 91 photos
Joined Aug 2012
Dec 29, 2016 18:25 |  #15
Download and burn win 10 ISO from here: https://www.microsoft.​com …are-download/windows10ISO (external link)
Download all Lenovo drivers for win 10 to removable media
Do a fresh install.
Another option is a factory reload. Lenovo might have an OS preload partition you can add access to get it back to 'take it out of the box' state.
5,696 views & 1 like for this thread, 7 members have posted to it and it is followed by 3 members.
1502 guests, 131 members online
