rebop wrote in post #18239404
I can see this in the lens. Period. Looks like a small piece of maybe black plastic. Trust me. Not sensor dust. Not lens dust.
The point we are all trying to make is that if you can see something in the lens, you won't see it causing a visible spot in the resulting image. To cast a shadow on the sensor that is visible as a spot the offending debris, be it a spot of oil or dust/dirt must be in contact with the surface of the sensor. this is because rays from any point on the focal plane will strike every point on the surface of the lens, and then be brought to focus at the focal plane. So from the point of view of the sensor the light is coming to any point on the surface of the sensor from every point on the lens, so it is like being outside on a cloudy day, when the light is coming from all directions, and you can't see any shadows. In fact because the light is coming from such a relatively wide area it is even hard for the dirt sitting on the "sensor" to cast a shadow. The sensor is actually a stack of many layers, with the sensor at the bottom, there are the microlenses, UV and IR filters, normally an OLPF, AKA the AA Filter, and the Bayer Colour Filter Array all sitting above the sensor itself which is also a 3D object. This is why it is always recommended to point the camera at a plain light coloured wall, and stop right down to the minimum aperture, usually f/22 on most DSLR lenses. This reduces the area that the light is coming from, and so maximises the shadow cast by the sensor dirt. Having a long exposure time is actually helpful, as is allowing the camera to move about, while pointing at the plain surface. This removes detail from the image, so that all you are left with is the sensor dirt. Even this process will not show up foreign objects or dirt/dust in the lens in the image.
I don't doubt that you can see something loose in the lens, however it will not be causing a spot to appear in the final image. Spots like this that show up especially well in areas of constant mid tones, such as the sky, are always caused by sensor dirt. Having the item in the lens is just coincidental. Dirt/dust and other debris in the lens tend to contribute to an overall lowering of image contrast, and may also increase the lenses susceptibility to flare. The other effect it may have is to change the shape of out of focus highlights. I have a 500mm catadioptric telephoto lens, and the half inch mirror mounted in the center of the front lens element definitely reduces the contrast of the image, and you get the classic donut shaped OOF highlights associated with this lens design. You definitely don't see it as a spot on the lens. With a digital sensor, which have issues with ray paths that come from off center out at the periphery of the sensor, due to that 3D nature of the sensor, Catadioptric lenses can also suffer more with vignetting when used on a digital sensor as they would have done when used with film. Perversely this makes the outside of the sensor darker, while the obstruction is in the center of the lens.
Alan
