Thread started 15 Jan 2017 (Sunday) 06:25
135 f2 or 70-200 f4
cubatahavana
I still don't see it
Gallery: 262 photos
Jan 15, 2017 06:25 |  #1
Ok, I have just started shooting weddings. I do more family shots and portraits at the moment. I have the 24-105 L and 70-200 as zooms and a 35 f2, 50 stm and 85 1.8 as primes. I am considering swapping the 70-200 for a 135 f2. Am I mad? I know the 70-200 will give me the benefit of having a zoom, but was thinking that for when I'm a bit tight and need it, the 24-105 should do just fine. I do love the photos taken with the 135. No IS, though. If I had the 2.8 II version of he 70-200 I don't think I'd be having this dilema...
Opinions?
My Flickr (external link)
My website (external link)
My instagram (external link)
dbs_jd
Gallery: 12 photos
Joined Mar 2014
Jan 15, 2017 11:33 |  #2
I'd take the 135mm f/2 vs the 70-200mm f/4 because of the aperture. You'll have more than twice the light in your camera, that is, low ISO in dark situations. I had a 70-200mm and I noticed that those 65mm less in the lens isn't so important because in most scenarios I could walk to get closer to my object. If I couldn't, I just cropped the photo a little bit and it still was a good result because the 135mm is crazy-sharp.
Another option could be the Tamron 70-200mm f/2.8 VC. I've seen it for like $800 and the 135mm is around $750.
As you said, a con of the 135mm is the lack of IS.
Gripped bad boi Canon XT, Sigma 50mm f/2.8 Macro || Canon 5D III, Sigma 24mm f/1.4 Art || Sony A7RIIIA, Sigma 105mm f/1.4 Art, Sigma 40mm f/1.4 Art, Sony 30mm f/3.5 Macro
umphotography
grabbing their Johnson
Gallery: 21 photos
Post edited over 6 years ago by umphotography.
Jan 16, 2017 13:27 |  #3
Both lens need 1/160 minimum shutter speed to use. probably 1/200-250 is better but depending on the camera your have it mounted on you need to be concerned with gate speed. Example 5D3 i could not go past 1/160 w/o seeing the gate in a flashed shot.
I think both are invaluable lens but I use the 135L almost all the time. The reason is F/2.0. Nothing but the 135 and the 200L provide that look at F/2.0...nothing else comes close. If im outside, the 135L is one of my most used lens
Mike
www.umphotography.com (external link)
Facebook (external link)
cubatahavana
Gallery: 262 photos
Jan 16, 2017 14:28 |  #4
You are making me move towards what I think I already knew. Probably I'll get the 135 soon... shouldn't be a problem to sell the 70-200
evolyllaphotography
Joined Dec 2016
Jan 17, 2017 06:38 |  #5
love my 135 f/2. i do weddings and the light weight is a big plus.
Toronto Wedding Photographer | Evolylla Photography (external link)
follow me on Instagram (external link); follow me on Facebook (external link); Canon and Leica shooter
frugivore
Gallery: 11 photos
Post edited over 6 years ago by frugivore.
Jan 17, 2017 06:46 |  #6
I use my 70-200mm quite a bit at weddings. Big churches, large banquet halls, outside for portraits.
It's not just the IS or the extra magnification that helps, but the narrower angle of view at 200mm helps remove unwanted objects from the background.
Also, being able to go from 200mm to 70mm in 1/10 second is not to be underestimated. I have two bodies on me when shooting and even with my vest/harness system, it's much slower to switch bodies if I had primes mounted.
I say keep the zoom.
tim
Light Bringer
Jan 17, 2017 15:52 |  #7
For weddings, if you have a modern camera that can do high ISO, or if you don't shoot in really dark venues, I'd take the 70-200 F4. Flexibility is more important to me than shutter speed, given I'm comfortable with high ISO. For portraits the F2 lens would probably be better, as you have more control on portrait shoots.
dbs_jd wrote in post #18245095 (external link)
F stop progression is 1.4, 2, 2.8, 4. Two F stops is quadruple the light, meaning a lower ISO or faster shutter speed.
cubatahavana
Gallery: 262 photos
Jan 17, 2017 16:02 |  #8
tim wrote in post #18247537 (external link)
5D MkIII, handles high iso pretty well :)
I know myself, I will end up having both :lol:
davidmtml
Joined Jun 2012
Feb 07, 2017 13:33 |  #9
If you haven't made a decision yet....
I own both a 70-200 2.8 (actually 2 of them, one Canon vii, and one Tamron) as well as a 135 f2L, and use them both frequently. When doing outdoor portraits, I will choose the 135mm 95% of the time. It really has a look that the 70-200 can't give, not to mention it vs an f4! People have mentioned having to use a higher shutter speed then normal, umphotography mentioned up to 1/250. I need to go even higher! I typically think I have a pretty steady hand, but I need to use my 135 at 1/400 to get consistently sharp photos. I really don't know what it is about this lens, but I just don't get consistent results even at 1/250. Pretty good keeper rate, yes, but not good enough.
Having said that...I much prefer to use my 70-200 during the ceremony and reception. I have less room to move around inside, so the zoom is invaluable. Plus I can shoot at 200mm at 1/40-1/50 and get sharp shots (as long as there isn't much subject movement of course).
Obviously I wouldn't want to live without either of them, but if I had to ONLY have one...it would be the 70-200...maybe :)
5,806 views & 6 likes for this thread, 7 members have posted to it and it is followed by 4 members.
135 f2 or 70-200 f4
1035 guests, 107 members online
